Old 05-01-2005, 08:34 PM   #1
SnS C10
SnS C10's Avatar
Question about Lowering 3/4 ton? please look
hey guys i noticed quite a few people here have questions about lowering 2wd 3/4 ton trucks. i have a lot of questions about how to do it to so i though i would as you guys about this setup up and what you guys think.
for the front: i sent an email to gmc pauls, and they told me 3 inch drop spindles for a 73-87 will fit on my 72 gmc 3/4 ton 2wd. no modifications, just take the old ones off, bolt them on. Early classic enterprises has 1 and 2 inch drop coil springs for the front that they say will also fit my truck. that would be 4 inches drop in front. i will also put lowered shocks on the front. is there anything else i need, what do u guys think about this setup?
for the back: gmc pauls says there 4 inch drop leaf springs will bolt right on my truck. the only draw back is that they will decrease my load capacity to a half ton truck, which i never carry anything, so it doesnt matter to me.
do you guys think the springs/spindles/shocks will be okay in front...is there anything else i will need????
In the back, is there anything else i need in order to put on 4 inch drop leafs in the back??? thanks
SnS C10 is offline   Reply With Quote
Old 05-01-2005, 09:47 PM   #2
kamikazegmc
Registered Smarta$$
kamikazegmc's Avatar
it sounds like you got it figured out.
63 GMC custom
going to be slammed
kamikazegmc is offline   Reply With Quote
Old 05-01-2005, 11:37 PM   #3
72MARIO
72MARIO's Avatar
Sounds like a Good setup.
Just a heads up dont try and use a 2" drop shackle on the back if you have a wood floor.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
