II Timothy 4:2
Need Firewall harness
While trying to figure out why my temp gauge wasn't working, I have discovered that the harness that the sender plugs into on the engine side of the firewall is melted from some electrical fire of yore. Does anybody have a plug with some wire on it so I can splice it onto the existing wires? From what I can tell, there are two plugs, one that's sort of a rectangle and one that is shaped like a backwards 'C'. I need the rectangle one. Here is a picture with an arrow pointing to it. Thanks!
(picture lifted/modified from this site. )
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus" MY TRUE PRIDE AND JOY "Dangit, Bobby, people will see that oil stain and think I'm a drunk." |
II Timothy 4:2
It doesn't have to be pretty . . .
![]() Join Date: Oct 2001
One is your forwardlight harness and the other is your engine harness.Besure to tell us if your truck has the deluxe gauges or just warning light for there is a difference.Also year model would help too!
Things happen for a reason! |
II Timothy 4:2
Sorry I forgot that. It's a 72 C-20 with gauges and a factory tach. I guess I need the engine harness plug.
I'll check the one I removed from my 72 C20 later today.
03 Tahoe 72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays. |
#6 | |
II Timothy 4:2
Give me a call. I work in Ft Worth, maybe I can get one to you.
817.689.3101 Thanks, Matthew
69 swb stepside, rebuild and upgrade in progress |
Harness
If Matt can't get one to you, this is what I have.
#9 | |
II Timothy 4:2
sent PM
II Timothy 4:2
Thanks Matt!
