Old 06-12-2002, 06:24 PM   #1
Kas68c10
Kas68c10's Avatar
Rear end is shot
Sad day, just got news the rear end is shot in the truck. Mechanic says $750 minimum to fix it.Pinion gear is wobbling all over. Anyone got a good rear end he wants to part with? My truck is a 68 Short box,half ton,coverted over to 5 lug. Not sure how that was done(bought it that way ) as I have read on the board it is not possible with a 68. Need some help, opinions, etc. Do you thinl I need to replace every thing in the rear, or just the pinion and chance it ?
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
Old 06-12-2002, 07:39 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
your rearend seems very badly worn, id look for a diffrent used rear axle in better shape...........
68SWB4x4 is offline   Reply With Quote
Old 06-12-2002, 07:47 PM   #3
COBALT
COBALT's Avatar
The pinion bearings (inner and outer) would have to be bought new. Since your originals were worn they've probably messed up both the pinion and the ring with a bad pattern. That would mean that your carrier bearings have been taking a pounding from so much deflection+wear in the carrier unit itself. Those damn things will make you poor, and I'm surprised the estimate is only $750.
No. I'd go with a new axle. Don't try to "chance it". Trust me. Take it from someone who was facing this dilema with a 10 bolt corp axle, and decided to have it fixed. It's great now, but it cost me $$$.
I'd try to get one off here, or try at a local wrecker. Worse case scenario you go and buy the new parts, and rebuild it yourself AFTER you've gotten a new one in the truck. Then you could learn (in theory)!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-12-2002, 07:54 PM   #4
Kas68c10
Kas68c10's Avatar
Yeah, the $750 was just a starting point.... Guess I will call the salvage yards tomorrow, see what they got. Problem is, in Michigan, most trucks ad old as mine are up to their axles in mud, not sure its much better....
Old 06-13-2002, 12:10 AM   #5
Mike C
Mike C's Avatar
$100 for installation kit including bearings, $175 for gear set and $250 labor. Maybe add $100 for miscellaneous seals and gaskets (axle bearings and seals, probaly only $50), and a grand total of $625. Sounds like your mechanic is bonin' ya'! I rebuild rears for $200 in the truck and $150 out of it, too bad you aren't in TX.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-13-2002, 02:36 AM   #6
primer67
primer67's Avatar
yup, expect to pay around a thousand after it is said and done. - did that whole scene two weeks ago, and am still recovering from it. - do it before it locks up on you though, I learned it the hard way. trailing arms are a biatch to locate too.
primer67 is offline   Reply With Quote
Old 06-13-2002, 09:20 AM   #7
Kas68c10
Kas68c10's Avatar
Do wish I lived in Tx Mike c, I would be callin ya....Worst part is, I just replaced springs, saddles,trailing arms,and cups. Had it all apart 4 weeks ago. Piss me off, gotta go do it again.Well, gotta call the salvage yards, maybe find a rebuilder....
