05-02-2005, 08:56 PM | #1 |
4WD Warning Light
Hi,
I have a 99 Blazer LS. Right now I have a warning light on my dash - 4WD Service. Before I take it in to have it looked at, can anyone tell me what it might be? Thanks for your time. Regards, Craig |
05-03-2005, 12:44 AM | #2 |
Professional Grade
Hey Craig!
Is the ECM giving any codes? With a 99, there are a large number of things that could be at fault, and not many guys here (myself included) will know exactly what could be wrong...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
05-05-2005, 12:52 AM | #3 |
I have a 2000 Blazer and mine did the same thing last fall. I figured something was stuck so I kept engaging and unengaging 4WD and even went in reverse a long distance and eventually it went off. No, problems since.
05-05-2005, 04:31 AM | #4 |
When my 2001 HD did it about a year ago. The GM dealer replace the 4WD switch on the dash and said it's common. I guess they replace quite a few of them. A friend of mine also had the same thing go bad on his 2000 Chevy 1500 4x4. Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) |
