Old 05-02-2005, 10:28 PM   #1
tnblazerk5
User #12137
tnblazerk5's Avatar
whats this front axle ?
whats this front axle ? i have never seen one that the chunk in in the middle ? i seen this pic at ck5 hope i dont getin trouble for the pic
tnblazerk5 is offline   Reply With Quote
Old 05-02-2005, 10:47 PM   #2
1969 GMC
1969 GMC's Avatar
that belongs to K5MONSTERCHEV over on CK5, he had a custom made 14 bolt center section/dana 60 end forgings/knuckles, front axle made. as far as I know it doesn't have axleshafts, its pretty much a posermobile. I do give it points for originality, tho.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-02-2005, 11:13 PM   #3
clarkjw24
I like cheese
clarkjw24's Avatar
Yep what he said. K5monsterchev is still working on it.
Cruiser: 1972 K5, 400/TH350/NP205, D44 and 12Bolt, 35 TSLs.
Trail rig: 86 K5, 350 TBI, SM465/NP205, 5.13s, 14ff locked, h1 beadlocks, 42" TSLs, 64" rears, 56" fronts, D60 locked, 35pline, drive flanges, crossover, hydro assist, OBA.
Tow rig: 2002 F350 PSD CC Dually FX4, chipped, cold air intake, BFGs
clarkjw24 is offline   Reply With Quote
Old 05-03-2005, 01:12 AM   #4
1FaastC10
1FaastC10's Avatar
im still not real sure why you would want to take something known to be a trail grader when drug the way it was intended, and turn it around and drag it backwards. should be damn near bulletproof though. originality is cool, especially when beef comes with it.
1FaastC10 is offline   Reply With Quote
Old 05-03-2005, 02:15 AM   #5
tnblazerk5
User #12137
tnblazerk5's Avatar
it just sturk me as odd that the chunk is in the middle hows the drive shaft goina work on it ? if he is running a chevy tranfer wount that be a problem or any transfer for that matter
Old 05-03-2005, 06:52 AM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Good point, if you look at the larger rear ends(14bolt, eaton, rear 60) the center section is actually offset slightly so the driveshaft comes in the center, so mounting the 14 b center section in the center actually offsets the driveshaft slightly.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-03-2005, 08:51 AM   #7
1969 GMC
1969 GMC's Avatar
Search on CK5, I remember reading about it. Not that I really understand why, but you will find info there.
1969 GMC K2500
1996 Honda Accord
Old 05-03-2005, 01:37 PM   #8
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yeah, it does not make much sense to me either but............ To each his own. Wonder how it will turn out?
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
