Old 05-03-2005, 12:30 AM   #1
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Exclamation help
does anyone have a qjet type carb for sale for cheap? Ive been having problems with my truck lately. thought it to be a vacuum leak. but I believe it is the carb taking a crap dive. I put a supposed right baseplate gasket on the carb and it ran like a dream for about 4 mins. then I went to turn right at a red light. and it died on me* like it had been* and I tried to start it, got it to run. but acted like it was on one cylinder and throwing black exhaust. so that tells me its just pouring raw gas down there. anyway long story about 30 mins and 1/2 mile *just went around the block to test it* later I got home. and noticed that when I was trying to back up. the exhaust was diesel black. I took out a couple sparkplugs and they were black. the cleanest they've been from oil. but none the less black and smelled of gas. so I put on the gasket that I changed and it runs under its own power. but still far from befor the problem started. and this is the only running car at the moment. and am acutaly looking for a new car if I cant get this thing runing well enoguht to get us by. thank you very much for your help. I am at my last hopes. matt
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 05-03-2005, 12:40 AM   #2
Drivin' Miss Daisy
Drivin' Miss Daisy's Avatar
I make no promises but I might have an extra out in the shop. I will check tomorrow and let you know.
Drivin' Miss Daisy is offline   Reply With Quote
Old 05-03-2005, 01:12 AM   #3
1974gmc
In Progress
1974gmc's Avatar
did u check to see if the choke was on?
1993 Chevrolet K2500 454 4L80E
1974 GMC 1/2t 2wd Stepside 305 auto *sold*
1985 Ford Mustang GT 5.0 5spd
1974gmc is offline   Reply With Quote
Old 05-03-2005, 01:35 AM   #4
79gmcc15
79gmcc15's Avatar
Great thank you
yeah the choke was open all the way. its broken.
RIP ELJAY
Old 05-03-2005, 09:21 AM   #5
Brad_Olson
Active Member
Brad_Olson's Avatar
Hmmm...when was the last time the carb was gone through? You could be having float and/or power piston problems, and those aren't usually too hard to fix.
Brad
Brad_Olson is offline   Reply With Quote
Old 05-03-2005, 10:44 AM   #6
86 GMG
around here in tulsa you can pick-up a remaned plain jane q-jet for about 125.00 a rebuild kit is about 40.00 to 60.00 paying someone is about 200.00 to 250.00 look into buying a remaned would be my choice GOOD LUCK
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 05-03-2005, 11:09 AM   #7
Drivin' Miss Daisy
Hey 79, I checked in the shop and I don't have a spare. You might check ebay and do a search for quadrajet carburetor. I've seen some go pretty cheap that might get you by for a while. Sorry I couldn't help you out more. Good luck.
Old 05-03-2005, 01:43 PM   #8
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Ya, I might have one of a late 70's motor that is going to be F.I. Not sure if I still have it or not. Supposedly got rebuilt a little while ago. Let me know if you interested and I will see if I can find it and get a price for ya if you want.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-03-2005, 02:01 PM   #9
79gmcc15
79gmcc15's Avatar
-Later
that would be great. thank you at this point I am looking for pretty much any type of carb. I figure I can always get the adaptor for the squarbore carbs. matt.... oh Brad_Olson as far as I know its never been rebuilt. I've never rebuilt a carb befor.
RIP ELJAY
Old 05-03-2005, 03:07 PM   #10
Russell
Professional Grade
Russell's Avatar
I have one!
I just used it to break my 355 in, so I am fairly sure it is good!
How does 50 + shipping sound? The carb was rebuilt shortly before I got it. I then ran it on my truck for several months before I pulled the engine out to re-condition it It sat for a while, but when I went to break the engine in, she fired right up like I ran it the day before (after priming the fuel bowl of course, lol)
Probally need to tune it up a bit though, its tuning is set for a 305, I just never bothered to tune it when I got it.
EDIT -- Oh yeah, its got an electric choke BTW
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 05-04-2005, 04:41 PM   #11
79gmcc15
79gmcc15's Avatar
well the truck whent to the dr. today and basicly found out that my truck is very tired. its better but it still has a bad drive/revurse idle. any ideas? btw the compresson was 150 all the way around except number 7 which was 160 and was fouled. could it still be the carb? he says the timing is good. the vacuume addvance holds vacuume. he did what he could do for a shade tree machanic. any help would be helpful. matt
RIP ELJAY
Old 05-04-2005, 07:36 PM   #12
white82
White 82
white82's Avatar
as long as the compressions are withen 20 pounds of each other u are fine say one is 150 one is 140 and 4 is 160 u are good ,but is u got one a 130 and 4 at 160 and one at 150 it is no good
1966 GTO 455 e-heads, 1982 Chevy k10 4'' lift 33’' tires, 2008 Pontiac g6 v6
white82 is offline   Reply With Quote
Old 05-04-2005, 08:49 PM   #13
Russell
Professional Grade
Russell's Avatar
That engine has better compression than mine does, mine was about 140 in all the cylinders! Try idling it up a bit, and see what that does. Also, see if you cannot borrow a vaccum gauge so you can check to see what kind of vaccum it is pulling. Should be 18 - 20 inches of vac or so.
Old 05-04-2005, 11:28 PM   #14
79gmcc15
79gmcc15's Avatar
I do have a vac gauge, just cant find it LOL. but with the amount of oil my motor goes through. it probably had some oil in there to bump the numbers up. she has a hesitation in her. the mechanic replaced all the plugs too. it helped alot. but she still bogs down when I get off a stop. and going up hills can be an adventure. when I left the guy, I was going up a rather steep hill *short but steep enough that when your driving and your going down you dont see the road lol. it was back firing and sputtering. which is something its never really done. and when I left my sisters *the place I was going* I was trying to start it and it reversed backfired and white smoke started billowing out of the motor. thought the dang thing was on fire. so shes got alot of problems. it has a rod/berring nock at start up. and needs new heads......Russell- can you give me a quote to ship the carb? zip is 98037. and is that carb for a th 350? were looking for a cheep car. to get mom to work. but were going to be moving and will need the truck to run good enough to do some work. just looking at all our options. if you guys got any more ideas. I will do my best to anwser them and mabe we can get the girl to last a little bit longer for me to have more money to figure out what would be best. that would be great. thanks for the helps. matt
RIP ELJAY
Old 05-04-2005, 11:46 PM   #15
Russell
Professional Grade
Russell's Avatar
Hmm, that sounds a bit more serious... White smoke = blown headgasket
Also, the sputtering on hills thing sounds like the float in your carb might be a bit messed up.
To be brutally honest with ya -- Why not find another running 350 and drop it in there? You can probally get it done within a week of evenings, or two long days if you have never done so before. I can get cheap 350s all day long, much easier than trying to keep a lemon running. Esspecially if the thing has a rod knock, and what sounds like a blown headgasket, not to mention the fact that it is burning oil...
However, I'll get ya the quote on that carb ASAP anyways
Old 05-05-2005, 01:46 AM   #16
79gmcc15
79gmcc15's Avatar
well because I live in an apartment and I dont have all the tools to do such a big task and I dont have the money to do that right now. but if I do keep the truck, that is something I want to do. I've been looking online *craigslist.org awesome website* and been seeing 305-454's for sale for pretty cheep. but right now. its just something I cant do. as much as it pains me. I've even looked at finding a truck simular to ours and yanking the good things off it. Ive seen a 77 chevy 1/2ton and the add says strong runner for 500 and thats the whole truck. so just if I get the rear and motor out of it and it lasts me till next year it would be worth it. oh yeah to put the cherry on top. my 12 bolt rear is whining and my starter is going out LOL these last couple days have been stress full lol. its like what else will go wrong!!! Lol thanks for looking for the quote. matt
RIP ELJAY
Old 05-05-2005, 10:09 AM   #17
Russell
Professional Grade
Russell's Avatar
Yeah, that would be tough then eh?
Well, we'll get this carb boxed up and a quote either this afternoon or tommorow
Old 05-05-2005, 01:02 PM   #18
79gmcc15
79gmcc15's Avatar
well just to let you know. the priority of the parents is geting a replacement car. so it might be middle of next week befor I can say ship it. but more then likely I'll take it. moneys geting very tight right now. find the cheepest shiping lol now that were looking for a new car the truck wont be drivin as much, so I wont be in a hurry to get it lol. but thanks
RIP ELJAY
Old 05-05-2005, 01:59 PM   #19
Russell
Professional Grade
Russell's Avatar
How about this then -- paypal 20 bucks, and it'll show up on your door step within a few days
Old 05-05-2005, 02:21 PM   #20
79gmcc15
79gmcc15's Avatar
I dont have paypal. whats involved to use it? I know nothing about them.
RIP ELJAY
Old 05-05-2005, 03:21 PM   #21
Russell
Professional Grade
Russell's Avatar
You give them your bank account number, and they safely transfer money to other people
However, a money order (not one of the green ones, I cannot cash them up here) or a crisp 20 will be fine
Old 05-05-2005, 04:23 PM   #22
79gmcc15
79gmcc15's Avatar
just to clarfi, your selling me the carb for $20?
RIP ELJAY
Old 05-05-2005, 07:03 PM   #23
Russell
Professional Grade
Russell's Avatar
20 shipped
