Old 05-03-2005, 01:35 AM   #1
davidh
davidh's Avatar
gear ratio for auto and std tranny's
Please correct me if I am wrong. In 67-72's Weren't the standard rear end gears for a manual tranny 3.73's and for automatic's weren't they 3.08's.? Given this was the std equipment. I know other's were orderd different. I was thinking of putting a 3.08 gears behind a 67 c10 with a 3speed for gas mileage.
davidh is offline   Reply With Quote
Old 05-03-2005, 02:24 AM   #2
1969 GMC
1969 GMC's Avatar
Gearing depended on what engine was ordered or came stock, but you could always order optional ratios. It didn't matter what tranny was used.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-03-2005, 10:49 AM   #3
Jason915
I have seen alot of trucks and I'll tell you most trucks with V8's came with 3.08's unless it had an optional gear. Often 6cyl trucks had lower gears but it really depends on how the truck was ordered but there are more 3.08 trucks than anyting else.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 05-03-2005, 11:31 AM   #4
Rod
You'd be better off assuming a 3.07 gear set in a 8 cyl and a 3.73 gear set in a 6 cyl as original equipment. It's not always the case, but it's a closer assumption. Manual trans really had not much to do with a truck having 3.73 gears or 3.07 gears.
3.07 gears behind a 6 cyl would still be drivable.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-03-2005, 12:35 PM   #5
vfrdude
vfrdude's Avatar
My truck came stock with a 3 speed manual trans, with 3.07 gears ( I believe cars had 3.08 gears). I ran the same gearing with the TH400. I've since installed a 700R4 and changed the gearing to 3.73's.
Rudy Fierros
'95 Honda VFR750F
Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it!
vfrdude is offline   Reply With Quote
Old 05-03-2005, 12:46 PM   #6
Bowtie67
Bowtie67's Avatar
I dont think I would want a 3sp with 3.07 gears, maybe 3.42's. 1st gear is pretty high and taking off in first gear would be a PIA, if you tow anything or haul any heavy loads you will more likey burn a clutch out in no time.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
