Old 05-03-2005, 10:27 AM   #1
dubie
dubie's Avatar
power steering hoses
I have a pump and box to install on my 72 but have a hose question. The pump is an 82 and the box is a 72, what should I be asking for at the parts counter? Are the boxes the same from 72-82? or should I just have a hose shop make me a pair?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-03-2005, 10:46 AM   #2
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Hey Dubie, i've got a power steering hose i'll give you if you want it. It's brand new, still has the tag on it from NAPA. Might save you $20-$25 bucks or so. pm me with your address if you think you might want it........Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 05-03-2005, 02:46 PM   #3
neonlarry
neonlarry's Avatar
If the 82 has a metric fitting (I'm not sure when they changed) and you have a 72 box you can swap the fitting on the box and use 72 hose.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-03-2005, 08:23 PM   #4
Dubie
I tried glancing through the FAQs, but could not find the thread. I remember, I believe TX Firefighter, talking about some metric to SAE thread adapters to make a new style box (metric) hook to old style pump and lines, so in my mind it should work with the pieces reversed.
You could go new style lines to old pump or old style lines at box, with adapters to the new pump (I think I would go that way).
Old 05-04-2005, 01:12 AM   #5
longhorn71
longhorn71's Avatar
Tim make sure the box is in fact metric.the 84 truck i took the box out of had standard S.A.E threads.You never know the box mighthave been older then the 84 truck it was on too.
longhorn71 is offline   Reply With Quote
Old 05-04-2005, 01:33 AM   #6
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i agree to check if it is SAE or metric. the part that screws into the back of the PS pump that the hose screws into will screw out and if you have an older pump that is SAE threads take that same part off and screw it in. while you have the pump out i would throw a seal kit at it. its easy and you can get the kit at the dealership. just dont put it back together till you are DONE cause it doesnt come back apart easily with the new O ring. ask me how i know
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
