Old 05-03-2005, 11:33 AM   #1
Woogeroo
Question big side mirror questions ? '65 c10
so I bought these painted big honkin' side mirrors and now I have a few questions about them.
1. what are these size and type side mirrors called?
2. is there a gasket that goes between the mirror bracket and the side of the truck door.. like there are on the other type mirrors ?
3. if there is a gasket... I doubt they make one.. so is it possibel to buy rubber gasket material and make my own to fit?
Thanks,
-W
Woogeroo is offline   Reply With Quote
Old 05-03-2005, 03:11 PM   #2
oldtrucksdave
1. I have always heard them called "west coast mirrors."
2. Yes.
3. Yes.
Are you sure you like them? They have always created a great deal of wind noise on my trucks, I replaced them with smaller ones. but thats my .02 worth if you like them have fun
Dave
1963 chevy 1/2 ton 4x4 283 4sp.
1962 1/2 ton 292 4sp.
1965 suburban sm.blk. 400 4sp. 3.73 posi.
oldtrucksdave is offline   Reply With Quote
Old 05-03-2005, 05:51 PM   #3
littlee_domn8r
AKA "Hurricane Hank"
littlee_domn8r's Avatar
Yep, they are West Coast Mirrors, I personally didn't like them on my truck. I replaced with the smaller original type.
"looking back, knowing that you gave it your all.... win or lose, you finish a Champion" Dale Earnhardt
"They say hard work never killed anyone, But why take a chance?
63 GMC C10 Custom LWB 355/350 AT
00 Chevy Silverado 1500 base V6/AT
07 Chevy Monte Carlo SS 5.3 V8
littlee_domn8r is offline   Reply With Quote
Old 05-03-2005, 06:33 PM   #4
64fleetside
I have a pair of rust free doors that are damaged from having those big mirrors solidly mounted, thye stick out a bunch & folks hit trees, garage doors, Sonic menus, etc. If you tow a lot they are great.
64fleetside is offline   Reply With Quote
Old 05-04-2005, 06:08 AM   #5
Woogeroo
Thanks folks.
64fleetside,
do you have any tips on mounting these up? Fastener type, bolts.. washer.. anything special required?
You always seem to have great little nuggets of info on these trucks.
Thanks to all.
-W
Old 05-04-2005, 08:57 AM   #6
64fleetside
The ones that were on the doors I have were just bolted w/nuts & bolts, 5/16 X 3/4" long or so, they did have a rubber mounting pad between the door & brackets. The top ones were easily accessible but the lowers are behind the door panel. Brian
Old 05-04-2005, 09:15 PM   #7
Woogeroo
Talking
Originally the top of the mirror fastened to the top edge of the door with funky little bolts like these and cap nuts. I have no idea where you might find something similar.
The bottom of the mirrors fasten with just a regular cap nuts, bolts and washers. Adding piece of flat stock behind the sheetmetal will add strength on the bottom.
-jeffrey / jhicken on chevytalk 60-66 forums
Well, that is an interesting bit I thought I would share.
I like the idea of puttin' flat stock behind the sheet metal.
-W
Old 05-04-2005, 10:15 PM   #8
64fleetside
A regular bolt & a grinder will replicate those oddball bolts, cap nuts are available in nickel or stainless at Lowe's, etc. A backup stip would be a good idea on the bottom mount. Brian
Old 08-29-2017, 12:01 PM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
Re: big side mirror questions ? '65 c10
I don't care for west coast mirrors also. They just don't cut the wind and my driver side one folds on the freeway and I don't get to use it anyway. I tightened it up but still folds.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
