Old 05-04-2005, 12:11 PM   #1
damage
Seat Spring Repair/replace?
Has anyone had any experience/luck with spring replacement or repair on a stock bench seat? In the middle of working on my seat, and the drivers side spring is so broke and mangled, there is barely a 2 inch piece left. Does anyone make replacement springs, or can I use a stiff piece of foam in its place? This is the spring on the far edge.
Thanks!
damage is offline   Reply With Quote
Old 05-04-2005, 12:55 PM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
shifty has first dibbs. http://67-72chevytrucks.com/vboard/s....php3?t=153139 Still gotta get those pics. Been working doubles. Dunno about replacements, I have not saw em. would not recommend using foam instead of the spring. Don't think it will hold up long term.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 05-04-2005, 01:13 PM   #3
damage
Thanks chickenwing, I posted in that thread just in case shifty's turn out to be ok. In case this falls through, anyone else have anything like this laying around?
Old 05-04-2005, 02:03 PM   #4
cdowns
cdowns's Avatar
any good local autoupholstery shop should have springs onhand
Old 05-04-2005, 02:04 PM   #5
shifty
Questionable
shifty's Avatar
Take next dibs. I have too many other resources at my fingertips to hold up another member and I wasn't able to get the seat of the truck this week as expected.
chickenwing: thanks for holding those for as long as you have. sorry i wasn't able to follow through, it's been a rough past two weeks
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
