Old 05-04-2005, 04:04 PM   #1
68haywagon
I'm watching you!
E-brake cable help
I tried the google search method but found nothing.
I replaced all the brake components on my truck. Before I did the e-brake did not work, I couldn't get enough tension on it. So when I did the brakes I replaced the cable under the truck. I don't know if I routed the cable correctly because the PO mangled the old one a bit. I thought I ran it correctly throught the loops. I have the cable adjusted all the way in and I have to pull the handle to the last notch before the brake engages . I know I got the right cable because I compared it to the old..the new was just a little bit shorter.
Does anyone have a pic of the correct routing? It's a 68 c-10 2wd longbed fleetside with 250 3-speed manual.
Any help is appreciated.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 05-04-2005, 04:12 PM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Don't have a pic. Went through the same thing. I was missing the lil wire guides that go through the frame rail just ahead of the tranny crossmember. They keep the cable close to the frame rails closer to the first brake cable.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 05-04-2005, 04:40 PM   #3
john
member #16
john's Avatar
Heres a pic from LMC if that helps. disregard arrows. John
john is offline   Reply With Quote
Old 05-04-2005, 04:51 PM   #4
69 Short Fleet
Great pic John, what manual is that from, the 67-72 Factory Assembly one whith the red & whate cover? Thanks Doug
69 Short Fleet is offline   Reply With Quote
Old 05-04-2005, 08:24 PM   #5
68haywagon
I'm watching you!
It's from the LMC catalog...I saw that right after it was posted...in my catalog. Completely forgot to check that out. The tabs after the metal loops...where are they? I may have missed them when I was putting the cable in. But I swear I didn't see anything like that. I'll have to double check when I go home again.
Thanks for the pic.
Mike
