05-04-2005, 07:58 PM | #1 |
Reverse light Housing Help needed.
I was just checking to make sure I have continuidity. The green wire is good but I can get a ground in the socket to the housing. Is that the way it should be ?
Thanks.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
05-04-2005, 08:48 PM | #2 |
With the shifter in the "R" position, you should be able to measure 12 volts between the green wire and the housing. I had one bacum light that wouldn't work until I tightened the housing screws a little to give it a good ground.
