Shortbox wanna-be.
OK, Now what is the widest rim to fit under rear of these trucks? (part 2)
First off, thanks for the replies to the last post.
Now, I guess what I really need to know is what is the widest RIM that could be installed between the fenders and the frame on these trucks? I do realize that the bed would need some mods, and the maybe the bump stops relocated, etc. But I don't want to actually have to narrow the frame. So by any chance would a 15" X 15" fit under there? (with proper backspacing of course) The reason I ask is because there is a set for sale here locally. ![]() Any help appreciated, and any pics would also be appreciated!! Thanks! Reid repo1@shaw.ca
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) ![]() |
Faster horses, yw, ow, mm
Make some cardboard cutouts for a trial fit.....z
'73 C20, 383, 3500 leaf springs, 38.5 Mickey Thompson Baja Claws (More ground clearance than an H2 Hummer), Performance Distributor (Tits!!) w/Clear cap (awesome at night), Edelbrock intake+IAS shocks, Tri Y headers, Dr. Gas Xover(for that NASCAR sound). |
A 15x15" wheel would physically fit but the gaps would be so tight that when cornering it would rub w/tire flex. A 15x14" would be the widest you would be able to go w/o touching the framerails & still not worry about tire rub.
Shortbox wanna-be.
Thats kinda what I was thinking. I guess I'll just keep my eyes open for some others.
Keep in mind that 14" wheel actually will measure 15" bead lip to bead lip. Double check the wheels your interested in & see exactly where the measurements were taken from as it's common to get diff measurements from diff people.
creator of kong
REPO1, I dunno if ya got my mail about wheels or not, but a 14 would fit under mine, but a 15 I think, might be pushing it.........I was all worried about clearance on these 15x12's and when I sat the bed on there, it swallowed these wheels and tires up......almost needs to be bigger, I think...........I am going to just space mine out for now and see if that helps....
