Old 05-04-2005, 10:31 PM   #1
z7199
z7199's Avatar
Will this work
I want to know if this will work in my 72' C20 2wd
click here
It is at the bottom of the page
GM 8-7/8'' 12-Bolt Truck, 30-Spline
109-5420105 64-82.5, 3.73-Up $332.99
109-5420107 64-82.5, 2.76-3.42 $332.99
99 nbs 5.3L x-cab Hypertech programmer
True dual 1 chamber flowmasters
magnaflow x-pipe 3" PA body lift
315/75/16 BFG All Terrian 15.3 @ 89mph
72' C20 402ci sc,lb in bed tool box, and new paint
http://www.cardomain.com/memberpage/456511/1
z7199 is offline   Reply With Quote
Old 05-05-2005, 05:45 AM   #2
HugrOrang71
Bite me, import boy
HugrOrang71's Avatar
The 12 bolt is a 1/2 ton differential. It won't work in your C20. They list a 14 bolt version, but it appears to be for a later model light duty version with a 9.5" ring gear.
Jason
'71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project
"Facts are meaningless, You can use facts to prove anything that's even remotely true."
HugrOrang71 is offline   Reply With Quote
Old 05-05-2005, 07:57 AM   #3
chevyfarmer
chevyfarmer's Avatar
I agree with the last post, looks to me like it is for a newer truck. Also, you might want to consider a different brand of posi unit. In that little picture next to my name is the 12 bolt out of my blazer project with a Auburn posi unit freshly installed. I joined the boards here shortly after that picture was taken and have many people say that the Auburn is okay...... but there are better options out there like a Eaton. Just my .02.
67 short wide 355ci 3 on tree
69 short wide 250ci 3 on tree
68 long wide 283 3 on tree
72 2wd Blazer project 454 5 speed
chevyfarmer is offline   Reply With Quote
Old 05-05-2005, 04:42 PM   #4
z7199
z7199's Avatar
I am willing to go with a diffrent locker but dont have a clue on what to get. Or the size of it or spline count or anything. What about one of those POWERTRAX that replaces the spider gears on open carriers
Old 05-06-2005, 07:04 AM   #5
HugrOrang71
Bite me, import boy
I think the question should be do you need a limited slip or a locker? What are you using it for? What rearend does your truck have?
Lockers tend to be somewhat harsh for street use. Sometimes you get a little clunking and banging and some tire chirp on corners and under accel and decel. And they can be a handful on wet pavement or other slippery surfaces if you're not careful. I run a old style Detroit in the back of my Bronco. While it is a trail rig, I do drive it to work from time to time. I have learned to live with it's street manners because it works well on the trail. I wouldn't have one on something that is driven primarily on the street though.
A limited slip would be better suited for a street driven pickup. You don't even notice that you have one until it is needed. The Eaton is a decent unit that will take a lot of abuse. A gear driven True Trac is one of the better limited slip units available, depending on what differential you have.
Jason
Old 05-06-2005, 06:52 PM   #6
z7199
z7199's Avatar
Yeah I would like the LSD but will live with a Locker I usally only drive the truck every now and then kinda like a sunday driver truck. I think the rearend is the dana 60 maybe not really sure but it is whatever it came stock with it.
