The oddest Todd around
quick simple question
I've always heard people saying that they would pull out their torque wrench for their lug nuts, but I've never heard how many ft/lbs of torque lug nuts are supposed to be.
So that's the question. How many ft/lbs of torque for lug nuts?
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
It might depend on what kind of rims you have. The tire shop told me to tighten the 15 x 10 alloys on a chevy 1/2 ton 68 - 70 ft/lbs. The first 300 miles I had to re tighten them 5 times since they were new wheels. My .02
67 short wide 355ci 3 on tree 69 short wide 250ci 3 on tree 68 long wide 283 3 on tree 72 2wd Blazer project 454 5 speed ![]() Last edited by chevyfarmer; 05-05-2005 at 11:11 AM. |
![]() ![]() Join Date: Jan 2005
My manual says 85 ft-lbs. That's what I have always done.
Got Light Emitting Diode?
the tire shop up here does 85-90 on my lugs. makes it a pain if you have to use a tire iron to take them off. on a 71 5 lug i believe the lug is bigger so it wuold have a higher torque rating
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
it's a 72 5 lug.
And it's steel rims.
Tighten the rears as tight as you want, tighten the front disc brake no more then 85, or you may cause warpage of the rotors.
Aluminum aftermarket wheels require you to re-chech ofton. |
