Cab Supports?
Can someone tell me what these are called, are they cab supports?
How are they replaced?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
67 is sold
Yep - your's aren't as bad as mine
Confirmed Truckaholic
![]() Join Date: Oct 2000
Yes, those are the cab supports. There are two types of replacements, one slips over your bad ones, kind of like a band-aid. The other one you would remove your rusted one first ,then weld or bolt in place depending on your talent.
I'm watching you!
Oh thats what cab supports look like
![]() Mike
2012 Chevrolet Silverado 1500 Z71 4WD 1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP) 1992 Chevrolet S10 - LS swap project 1968 Chevrolet C-10 longbed fleetside - sold ![]() |
Yep, cab supports and they can be a real pain in the butt, depending on what kind of tools and facilities you have to work with. I opted to replace them with the cab still on the truck and mounted with a combination of bolts and my trusty little stick welder. But if you have a good MIG welder its much easier. My problem was burning thru the floor panels, thats why I decided to just drill thru the flanges and floor and inserted bolts while tack welding the areas I could mate together.
front left - before and after
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. Last edited by Southpa; 05-05-2005 at 12:05 PM. |
I like the idea of a bolt in replacement as I can do it, but I think the cab needs one corner replaced, and therefore will probably go to a shop.
