Old 05-05-2005, 02:46 PM   #1
damage
Center Cross Member
I'm not sure where this image came from that was on my computer, but I'm wondering where I can get something like this. I did a quick search on a few parts vendors, and ealry classis has one simular but for a four link rear. Any ideas? I think it would be nice to run the exhaust through there and tuck it under the truck a little more.
damage is offline   Reply With Quote
Old 05-05-2005, 03:54 PM   #2
CHEVYE
my gas saver
CHEVYE's Avatar
i believe a few trucks came factory like that. i'm sure there's a way you can cut yours, and i'd like to see if you can do that. mine is down to the frame right now and i'd do it if i could. does anyone know if there would be any issues with cutting it???
85' SWB, 4.3/TH350, getting ready for paint
84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black
71`SWB, project
ebay feedback
CHEVYE is offline   Reply With Quote
Old 05-05-2005, 07:54 PM   #3
MOTHERTRUCKERS
We have them in our suspension section for trailing arm trucks.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 05-06-2005, 12:36 AM   #4
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
if you decide to modify yours you will need to flange the hole after cutting it.
'70 chevy lwb w/'67 hood.
357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada.....
'82 honda v45 sabre"the black"
CHEVIBUBBA is offline   Reply With Quote
Old 05-06-2005, 10:33 AM   #5
NPilot1975
NPilot1975's Avatar
The ECE crossmember is designed for the trailing are suspensions. It comes with the trailing arm mounts bolted to it.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
