Old 05-05-2005, 06:20 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Does Anyone Know??
I am driving my 87 4x2 Burb (350 with 700R4 -- 125,000 miles) home from the mall and at about 50MPH I get a serious vibration. My tires are as hard as a rock and it is smooth as glass berore 50 MPH..The belt is off my a/c so it cant be the compressor.. Does anyone have any idea what it might be? trans??, U-joint?? HELP !!!!!!!!!
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-05-2005, 09:32 PM   #2
screwballl
Tonawanda 454
screwballl's Avatar
i get a slight sluggishness and vibration around 50-57mph on my 91... i am having someone look at it shortly and will let you know if it may be related...
usually in that case i have heard it is a bad spot in a U-Joint or rearend (gears)
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 05-07-2005, 11:35 PM   #3
aggiedave98
sounds like a driveline vibration... did you put in a lift or anything? If not, then replace ujoints...
aggiedave98 is offline   Reply With Quote
Old 05-09-2005, 12:54 PM   #4
Already Gone
Thanks for the help guys. I am kinda thinking its either the u joints or steady bearing as I havent done anything to the suspension.
