Headers on a manual truck.
So I decided to install some headers on my truck. Much to my surprise, they didnt just drop in. I ended up having to remove my starter, spark plugs, Brake booster, manual truck linkage, and wheel wells. My clutch linkage had to be modified and spark plug wires changed for clearance. In the end it would have been just as easy to remove the whole engine and install the headers with the engine out. Learned alot though.
I just cant wait till the headers rust up in 6 months and have to install new ones ![]() Next time im going with block huggers or tri-y's. |
Precisely the reason I wont be putting headers on my truck. I'll wait to find a set of vette ramhorns before I go through all that headache. Hope they work out for ya rooster.
-Cory 1967 2 Wheel Chevy |
Wow, what kinda truck and what kinda headers ?
#4 | |
The LuvShack Garage
YEA, WHAT HE SAID, I ONLY HAD TO REMOVE MY SPARK PLUGS ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
no kidding, my hooker comps and super comps have both been a dream to install, pull out the plugs and pop em in. took about 2 hours to R & R both times. all i had to do for the auto was bend the linkage slightly and for the manual it was a complete bolt in.
Ryan |
huh ???
I can R & R the headers on my big block in about 35 minutes...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
Hey Ryanroo,Which headers did you use on the manual truck,4wd?LUV,yours is an automatic,right?1stTime,rams horns are good,headers are better.Rooster,how would using Tri-ys help?What vehicle/headers are we talking about?Clutch linkage problem is all I`ve experienced.
i used hooker super comps on my manual truck, no interferance with the linkage at all. the pipe did have to make a imediate bend to clear the crosmember and the t-case but it wasn't severe. the super comps were the easier to install than the comps, but jsut a little.
Ryan |
dang, I have junky flow techs on my truck and they were fairly easy to install just removed the plugs and the clutch linkage.
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's 1970 K5 TBI conversion lifted etc SOLD 1968 C20 camper truck SOLD “To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder |
#10 | |
The LuvShack Garage
YES, 350 TURBO AUTOMATIC / NP-205 TRANS. CASE, PIC'S OF MY HEADER SWAP UNDER "GQ" LINK IN SIG ![]()
I installed some headman headers w/ heat wraps
http://static.summitracing.com/globa...ed-69097_w.jpg on a 67 swb gmc w/ 327 engine and a 4-speed manual trans. The bastards would not just drop in. the clutch linkage would hit against the header pipes so i had to modify it(cut, reposition, weld). Removing of the starter and brake booster is fairly easy but I had never dealt with the clutch linkage. Special-K: I figure if im going to go thru all that trouble I might as well pay up and get some Tri-Y stainless steels. I had seen so many tutorials and pictures of them going in so easy. It seems that everyone elses went in with out ant trouble, does anyone know how I could of done it easier? |
When I did my flowtech's on my '71 I had to remove the plugs, starter, and clutch linkage also. I guess it wasn't that big a deal because that's what I was told I had to do to get them in, so I was ready when they got here. When I can get some better headers it should be easier beacuse the 3 on the tree is gone and the TH 350 is in.
Steven
2002 Silverado 2500HD LB7 CCSB LT EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's 2004 Tahoe LT 2006 Silverado Z71 LS 1971 Chevy C10 Last edited by 1978steven; 05-07-2005 at 12:40 AM. |
#13 |
I`d like to run tri-ys on my manual 4wd for torque.But,hesitate unless I can confirm they`ll clear the clutch linkage.I put Headman Torque-Steps in my GMC/auto with no problems.In the past,I`ve cut and repositioned the one leg on the clutch linkage.That`s a pain,but it works.I`m afraid to have them run straight through where the tube is for linkage.It looks like I`ll go with Hooker Super Comps next time I redo exhaust on that truck.Thanks Ryanroo,I know what you`re saying about the bend to get over the crossmember.Not a bad thing,though.
