Old 05-05-2005, 11:01 PM   #1
Broken_down?
Altinator volatge question
I have a computer. and a small laptop screen both pulling 120v (theoreticaly) I want to run it in truck. How much would I have to upgrade my altintor to keep a good charging system?
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 05-05-2005, 11:48 PM   #2
Green Machine
Green Machine's Avatar
Volts X Amps = Watts. Check the amp draw listed on your equipment. Typical computer and monitor draw about 1 amp each. 2 amps times 120 volts =240 watts.
240 watts divided by 12 volts = 20 amps. Figure 10 percent loss through the inverter and your're at 22 amps. Your cig lighter may have only a 15 amp fuse which would not last long. You may hve to run a seperate FUSED feed from the battery. Some alternators were rated only 35 amps, so if your're running the lights and heater fan, your're almost maxed already. I run a 400 watt invertor in my wifes van and can only plug in 1 laptop, if I try 2 laptops, the lighter fuse blows, but the larger alternator handles it OK. Depends on how often your want to use the equipment too.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
