Old 05-06-2005, 11:03 AM   #1
roadking
edelblock 1406 hard starting
im having problems with hard starting when my truck is cold, talking to the edelblock rep. he says i need to put a fuel pressure reg. on and tune it to 6psi. truck has a new crate engine with a stock (new) fuel pump that runs great once warm.. has anyone had the same problem corrected with putting fuel reg. on these carbs?
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
roadking is offline   Reply With Quote
Old 05-06-2005, 11:10 AM   #2
RON WOODGEARD
Resident Young Old Dude !
I don't want to argue with no Rep. But he doesn't even know what pressure you have now. It sounds more like a Choke adjustment ( or lack of) to me.. Or even a partially plugged fuel filter?? But I still lean towards the Choke.
RON WOODGEARD is offline   Reply With Quote
Old 05-06-2005, 11:22 AM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
I have the same carb you do on a rebuilt 350. I have the electric choke on mine. I usually hit the pedal once in the mornings and it will fire on the first crank (even cold days). I don't have to do it again if it has been running that day. Do you have the manual choke? The 6psi sounds like BS. A stock truck engine should not need a pressure regulator unless you have tons of hp, and electronic fuel pump, or fuel injection.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-06-2005, 11:26 AM   #4
67chevemall
67chevemall's Avatar
I put a reg. on my truck for 10 minutes then chucked it to the ebay pile!
Garbage.
Good with electric pumps though.
67chevemall is offline   Reply With Quote
Old 05-06-2005, 11:34 AM   #5
'70_402
'70_402's Avatar
i have the cure for all your problems.. i have a street avenger for sale on the parts board. that will cure your edelbrock probs.
'70_402 is offline   Reply With Quote
Old 05-06-2005, 11:54 AM   #6
COBALT
COBALT's Avatar
Oh nice try dude.
What he's suffering from sounds like poor fuel/air @ idle on cold start-up. if it's an electric choke verify you have 12v to the choke first. It should be getting juice from an ignition connection on your fuse pannel.
Then just give the gas petal a pump to set the throttle. It throws just enough fuel over the venturis for it to idle at the right rpm for warm-up. I usually wait for the temp guage to reach the first line before idling down and driving away.
As for fuel pressure that's easy to tell if you're running rich or lean. Out of the box the 1406 is pretty well tuned for a 350 - stock, crate or not in my opinion. It's pretty middle of the road. If you have a stock mechanical fuel pump you will probably have more luck without a regulator. it's when people opt for electric pumps or aftermarket mechanical ones where the problems with PSI start I think. Some new fuel line, and a pressure guage will tell you right away what your fuel pressure is from the pump.
After that it's adjusting the fast idle, the accel pump arm, and the needles and seats to get the best performance.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 05-06-2005, 12:14 PM   #7
Lemield
Lemield's Avatar
I have an Edebrock on my 383 stroker....same type of problem. If truck sits for a few days, I have to pump throttle 10-12 times before truck will even think of starting. Edelbrock mechanical fuel pump too.
I'll be watching this thread for an answer.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 05-06-2005, 12:23 PM   #8
'70_402
'70_402's Avatar
Originally Posted by COBALT
Oh nice try dude.
hey whats a guy to do.
Old 05-06-2005, 12:38 PM   #9
Guff
Guff's Avatar
Ditto on that.
I have the same carb and I experienced the same symptoms until I got the 12V and ground wires connected properly. Now I tap the throttle once and the truck fires right up every time.
-Guff
1969 C10 LWB, 350, 700R4, 3.73 gears
Guff is offline   Reply With Quote
Old 05-06-2005, 12:41 PM   #10
toddtheodd
The oddest Todd around
toddtheodd's Avatar
I have a manual choke edelbrock, and have a similar problem.
I think I'm just going to replace it with something else when I rebuild the motor.
Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 05-06-2005, 01:28 PM   #11
ac102nv
ac102nv's Avatar
im having problems with hard starting when my truck is cold.....
Roadking, could you describe the problem in more detail? Hard start...have to crank for a long time, starts up then dies, etc. Also, does it do this after sitting overnight or after truck has sat for 3,4, more days? This might help diagnose the trouble.
'72 C10 lwb 454/TH400
ac102nv is offline   Reply With Quote
Old 05-06-2005, 02:06 PM   #12
jamis
F.A.S.T. president
jamis's Avatar
I notice these Edelbrocks need the choke to start as well, the acelerator pump just doesnt dump enough fuel like holleys or Q-jets do. I never had to choke a holley.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 05-06-2005, 03:30 PM   #13
roadking
i do have the electric choke which seems to be working fine, i can set the choke with one pump( butterfly in the almost closed position when cold, staight up and down when engines warm) engine starts to fire but only runs for a few seconds.i then have to pump the accelerater a few times to get it to start. sometimes when its warm i have to pump accelerater a few times to start.??
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
Old 05-06-2005, 04:02 PM   #14
72MARIO
72MARIO's Avatar
I think I am seeing more and mor epeeople agree that these carbs are Junky.
I have a 1406 on my 355 in my 84 and Dads got one on his 73 with a 383. We have been told the fule pressure should be 6 psi max. And some pumps need it stock of not.
Both of our truck suffer from poor starting when they have been sitting for a couple of day and extremely difficult starting when hot about 5-10 minutes after shut down. A insulated carb gasket should correct it but we have not made the time to install it. If I havd the money I would try the pressure regulator.
MArio
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-06-2005, 04:03 PM   #15
72MARIO
72MARIO's Avatar
Oh mine does exactly what you decribed I dont have a clue why but it make me look like I am driving a piece of junk.
2005 TAHOE DD
Old 05-06-2005, 07:45 PM   #16
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
ok.all you guys/gals who think your edelbrocks are junk or just don't want it anymore, please send them to me.i'll give $10 each for your junk carbs & i'll pay shipping.
this offer NOT good for holley's.
for holley's, send me $100 & pay shipping & i might take that junk to the salvage yard for you.
roadking, have you verified your float level?
your new fuel pump could have a pin hole in the diaphragm.
'70 chevy lwb w/'67 hood.
357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada.....
'82 honda v45 sabre"the black"
CHEVIBUBBA is offline   Reply With Quote
Old 05-06-2005, 07:49 PM   #17
Cethern
What was I thinking??
Cethern's Avatar
I had a 1406 on a crate motor that was in my 83K5 and never had a lick of problem out of it. It was on that Motor for 5yrs and still running fine when I sold the K5.
I would try what Cobalt has said. or at lest take a good look at those areas.
72 K5 that needs lots of parts..
71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit...
Cethern is offline   Reply With Quote
Old 05-06-2005, 09:18 PM   #18
bisquik65
bisquik65's Avatar
[QUOTE=72MARIO]I think I am seeing more and mor epeeople agree that these carbs are Junky.
I have them on all of mine,The electric chokes work fine,after 3-4 days sitting you do have to crank the motor a few times to get fuel up,But at least you don't have to change a power valve every other day!!! Every time your motor sneezes No holleys here,I have 4 here sitting on the posch ready to go in the scrap pile...
bisquik65 is offline   Reply With Quote
Old 05-06-2005, 09:40 PM   #19
tmcgrawlookalike
i`ll take all your holleys,and i`ll take everyone else`s edelbrocks,hell,i want everyone`s junky carbs,no matter what brand they are.send them to.......
tmcgrawlookalike is offline   Reply With Quote
Old 05-07-2005, 08:31 AM   #20
72MARIO
72MARIO's Avatar
Try setting the choke on a day thats -15 then the 2 weeks later go to start it when it's + 10 and the choke does not come on. Not like a Q jet set it and leave it.
Mabe they are good for the deep south but not up here. Set it when it's +15 and it will not come off when it's -10.
I pulled my carb apart and reset the float level. Did not help me.
2005 TAHOE DD
Old 05-07-2005, 10:58 AM   #21
bisquik65
bisquik65's Avatar
72mario, Man i was kidding about the carbs.... You need injection for those cold temps!!
Old 05-07-2005, 11:23 AM   #22
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
I've run both a 1406 and now a 1411 on BB and never have had a cold start or a problem after sitting for a long time .
But it never gets below 36 here.
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 05-07-2005, 08:39 PM   #23
jamis
F.A.S.T. president
jamis's Avatar
I think injection has spoiled us all.......were just not use to having to deal with the irregularities of carbs, no matter who makes them
Old 05-07-2005, 09:40 PM   #24
flip66
flip66's Avatar
Check the float level and the choke also check the fast ideal setting. I did notice when I adjusted my float level it started better I can tape the gas and it will start right up. Make sure the float is set just like the book shows
1998 Pontiac Grad Prix GTP
1969 C10 396 TH400 3.08 posi
flip66 is offline   Reply With Quote
Old 05-07-2005, 09:42 PM   #25
68 Stepside
huh?
68 Stepside's Avatar
The Holley/Edelbrock (Carter) debate will NEVER end, I know that much
I've had a 1406 on my 406 for over a year now, and have had 0 problems. My truck hasn't run in a few weeks, and a guarantee I could go out there, pump it twice without choking it, and it would fire right off. The only time I had to choke it was after it sat for 2 months this winter, and even then I only had to pump it a few times. Anyway, it's not worth the time seeing who can piss farther by arguing for or against one carb or another.
Either way, it sounds like there's an air/fuel problem, maybe the carb needs a thorough tuning?
I've heard of people using regulators on these carbs with stock pumps, but I haven't seen the need to with mine anyway.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
