Old 05-06-2005, 05:00 PM   #1
jlaird
jlaird's Avatar
what size notch?
At what point is a step notch needed versus the traditional C-notch? What I mean is, what else do you need to do to your rear suspension to warrant the extra axle(really frame) movement a step notch provides? A 4 link maybe?
What I'm getting at is if I want to run bags in place of coils with a 2" drop block, will I need more than a c-notch?
If I do a 4-link, is say a 8" step notch a definate?
I know wheel size is a factor so FYI, I want to run 20's.
I kind of asked this in another post, but I would like to start another dedicated to this subject.
To take the question one step further, say I do need something more than a c-notch. Am I looking at some custom fabrication for the notch or is there something I can buy. I know Suicidedoors has the weld in 8" notch, but that doesn't really take into consideration the bend in our frames right above the axle right? So the SD kit would need to be modified to fit the curve??
thanks for any knowledge you can drop (pun intended!)
jlaird is offline   Reply With Quote
Old 05-07-2005, 10:29 AM   #2
laid67c10
laid67c10's Avatar
it depends on how low you want to go if you want to lay frame on 20's yes a step notch will be needed if you just want it to sit low you can get away with a c-notch if you want it to lay all the way down also at some point the trailering arms bottom out on the frame you, i am gonna 4 link mine and as far as a step notch i got mine from SD and i am gonna build a new rear frame section to eliminate the bend....
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!!
09 - Harley nighttrain on air ride!
laid67c10 is offline   Reply With Quote
Old 05-07-2005, 12:36 PM   #3
jlaird
jlaird's Avatar
I want it low, and low enough that I'm not going to say "I wish I went lower." So I'm kind of undecided, that's why I'm asking these questions. Thanks for the reply.
Old 05-07-2005, 01:04 PM   #4
pbmcauliffe
pbmcauliffe's Avatar
When I notched mine the first time I did a large notch that almost is thru the whole frame height, but fits under the bed with massaging of the bed supports. With the bags, 2" blocks and a small hole in the bed for the dif. the back it goes down until the axle is resting on the notch and about 3/4" more drop available if the notch was bigger. I am only running a 15" rim and a tall tire, so would look different with 20's. When I do the x-member drop in the front, I will 4-link the rear and go to a larger notch to get lower.
pbmcauliffe is offline   Reply With Quote
Old 05-07-2005, 03:23 PM   #5
XXL
Seņor Member
XXL's Avatar
With bolt-in notch we've discussed in PM's...
XXL is offline   Reply With Quote
Old 05-07-2005, 05:06 PM   #6
jlaird
jlaird's Avatar
Thanks for the pics. What is your overall tire height on both of those trucks?
pbmcauliffe, got a side view?
Old 05-07-2005, 06:06 PM   #7
XXL
Seņor Member
XXL's Avatar
255/50-17 on all 4 corners. They're ~ 27" tall. In that pic, the rearend is sitting on the notch ( = zero travel), which puts the pumpkin of the rearend just pushing through a stock wood floor-- I am told metal floor may actually still have clearance but can't verify. You'll also have to notch the wide xmember where the rear shocks mount with just a little relief cut on the trailing edge. This will allow the 3rd member portion of the rearend to clear.
Old 05-07-2005, 09:01 PM   #8
pbmcauliffe
Only other side shot I have right now, I will be at the shop tomorrow and try to remeber to get a side shot by itself.
rear tires are 275/60/15 on a 15x8, front are 205/something/15 on 15x7
Old 05-08-2005, 09:14 PM   #9
phantom dually
Project92 SWB stepside
phantom dually's Avatar
You could always get a c notch for your truck with the curve and mod it. Or you could build your own notch. I have a 8" notch from SD but its for a 88-98 truck. Im like you, I want to go big enough the first time.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 05-09-2005, 12:39 AM   #10
Rollie396
someday it will be done!
Rollie396's Avatar
Don't know how much this will help,but I just finished installing bags with a 2.5" c-notch and have found that there is nowhere near enough room in that size of notch for drop blocks.Without blocks,the axle is about a 1/2" from the top of the notch and the trailing arms (just fyi) are approx. an inch from hitting the frame with the bags flat.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 05-09-2005, 12:36 PM   #11
Slammed67
Progress = 0%
Slammed67's Avatar
The bolt-in c-notches (along with the supplied rubber bumpers) are designed to work with a stock bed floor. If you remove the bumpers, you gain about 1.5" more drop, but also created a bed floor interference issue. To solve this problem I raised my bed floor 1.5" instead of just cutting a hole in the floor (which is kind of ghetto in my opinion). And as XXL stated, if you remove the bumpers you also have to notch the cross member directly above the differential, but it's only a minor notch.
Here is a picture of mine with the axle resting on the bolt-in c-notch (rubber bumpers removed). 27” tall tires.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 05-10-2005, 02:29 AM   #12
ricecop425
carl
ricecop425's Avatar
damn that is sick slammed 67, what are you running up front?
a man and his truck, such a beautiful thing
ricecop425 is offline   Reply With Quote
