Old 05-06-2005, 07:57 PM   #1
joelboxt
71 Cheyenne SWB Fleetside
joelboxt's Avatar
Talking electric water pump? good idea?
have noticed electric water pumps for sale lately are they a good idea for a weekend driver? i would assume you would maybe need a higher amp alternator? what are the pro's and con's of electric pumps ver. the belt drive units?
thanks,
joel
joelboxt is offline   Reply With Quote
Old 05-06-2005, 08:03 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
good question, inquiring minds want to know
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-06-2005, 08:06 PM   #3
bigjimzlll
bigjimzlll's Avatar
The biggest advantage to an electric water pump is the ability to cool the engine down between rounds of drag racing. They can cut some parasititic drag(15HP) along with an electric fan your looking at 30-35HP. I have used the moroso drive kit and a proform electric water pump. They both seem to put ot plenty of water(cool a 12.5-1 406 on N20)...never goes above 190 without a T stat. They also weigh less than a cast pump with pulley and belt.
You will need to fab an alternator brkt or get an after market on(too shorten the belt)
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 05-06-2005, 08:49 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Acording to what I've read, they don't really flow enough for the street.
Old 05-06-2005, 08:50 PM   #5
cdowns
cdowns's Avatar
well the one thing i can think of if a conventional pump fails you can go into any parts store anywhere and get a replacement for about $20 replace it and be back on the road in less than an hour, happened to me when i was moving from n.y. to fla . with an electric who knows you might be in a motel for a few days or more then end up having to buy all the pulleys and stuff to switch back to conventional just to get on the road again.
Old 05-06-2005, 09:15 PM   #6
68w/sbc406
68w/sbc406's Avatar
well what is the gpm on a conventional pump during light to light driving compared to an electric one??
Old 05-06-2005, 09:24 PM   #7
GloryHound
Working on a Nova.
GloryHound's Avatar
I've heard the electric really are not meant for street use. They tend to wear out more quickly and do not work well with an old style thermostat unless you use a seperate thermastat that can turn a relay on to turn the pump on once you usual thermostat has opened up. If you run with out a thermostat in the housing you could end up with no heater in the winter or on a cold morning.
GloryHound is offline   Reply With Quote
Old 05-06-2005, 09:40 PM   #8
kelsfine69
18 Till I Die
kelsfine69's Avatar
Had a stock BBC pump, switched to Moroso drive kit. Ran too hot not good for steet use , Now have aluminum Edelbrock pump....much beter cooling. They have a CNC machined impeller compared to other stamped steel impellers
kelsfine69 is offline   Reply With Quote
