Old 05-06-2005, 09:05 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Anybody have the link on Auto Meter gauges?
I'm probably overlooking it but I can't find it and I have gone thru alot of pages so far. Anybody have the link for the conversion?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-07-2005, 06:49 AM   #2
Bowtie67
Bowtie67's Avatar
Here is a previous post that has some dash picks with Autometer gages
http://67-72chevytrucks.com/vboard/s....php3?t=104204
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 05-07-2005, 10:20 AM   #3
70c10
67-72 Addict!
70c10's Avatar
Thanks Bowtie67 but I was looking for the write up on how to modify a factory bezel. Your truck is awesome! Hey did you get my PM?
Jim
Old 05-07-2005, 10:29 AM   #4
1972ChevyCheyenne
http://classictrucks.com/tech/cl_0311_6772dash
Is it this one?
Jamie
1972ChevyCheyenne is offline   Reply With Quote
Old 05-07-2005, 02:54 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Thanks Jamie!. That helps also. I was looking for the one written up in the FAQ section.
Jim
Old 05-07-2005, 04:18 PM   #6
Bowtie67
Bowtie67's Avatar
Yes, Screaming C10 is taking the dash..
2009 Toyota Tundra
Old 05-08-2005, 12:05 AM   #7
70c10
67-72 Addict!
70c10's Avatar
Thanks anyway Bowtie67
Jim
Old 05-12-2005, 11:46 PM   #8
garthdader
I know you posted a few days ago but I have done this myself. 2 1/8 in gauges fit into the bottom 4 holes without any work. The top 3 are the problem. If you are really patient and careful with a dremel you can make the holes larger yourself. I would use a 5 in hole saw and a drill press if I could re-do it. I would have to say that the best advise that I can give is buy one from covans classics or make a custom insert from scratch. I made one from diamond plate also.
1971 Chevy 6" superlift 35" xterrains 350 VORTEC crate
garthdader is offline   Reply With Quote
Old 05-13-2005, 03:02 AM   #9
Mudder
Mudder's Avatar
I used Autometers and I didnt have to do anything to the top holes. The bottom I added 2 5/8 guages and I had to make them a little bigger. I practiced on a brand new bezel. I found a 3 3/8 inch clock that is black faced that would look good in the middle hole if anyone is interested.
Mudder is offline   Reply With Quote
Old 05-13-2005, 07:22 AM   #10
70c10
67-72 Addict!
70c10's Avatar
Thanks for the insight garthdader. I guess when you use Auto Meters, you only use the top bezel only not the green or black tins?
Randy I'm assuming you used the dremel to shave away some plastic?. Can you post a pic of your clock?. I forgot you had that setup.
Jim
Old 05-13-2005, 09:12 AM   #11
Putter
More Cowbell....
Putter's Avatar
I know which thread you are looking for, but darned if I can find it either. It seems to have vanished.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 05-13-2005, 09:16 AM   #12
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i am looking to do this soon, but they dont make a 3 3\8 fuel anymore
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-13-2005, 09:28 AM   #13
Putter
More Cowbell....
Putter's Avatar
But you can still find the 3-3/8 oil pressure, oil temp, fuel pressure, and water temp.... in black face Pro-Comp, or even in the Pro-Comp Phantom.
Phantom p/n: 5829 for Oil Pressure & 5839 for Water temp
Black p/n: 5507 for Water temp, 5502 for fuel pressure, 5510 & 5511 for oil temp (yes temp, not pressure)
Old 05-13-2005, 09:56 AM   #14
Mudder
Mudder's Avatar
Yes i used a dremel to make the bottom holes larger. Basically just trimmed all the chrome out of the hole. They fit good and snug.
As far as the black faced guages? I think u will be very lucky if you find them. The white faced (Phantom) you can still find.
Someone found this clock that is sold by Moon that I think would look good in the middle hole. It is advertised as 3 3/8.
Old 05-13-2005, 09:59 AM   #15
70c10
67-72 Addict!
70c10's Avatar
Thanks Randy. That would look cool with orange hands on the clock to match the gauges.
Jim
Old 05-13-2005, 05:03 PM   #16
GMC69mnypit
!Women...!!!!
GMC69mnypit's Avatar
Jim,
I think this may be the link you were looking for. It has vanished from the FAQ section, this is a cached page from google, unfortunate, all the pictures are gone.
http://64.233.167.104/custom?q=cache...hl=en&ie=UTF-8
Hope this helps
-Brandon
GMC69mnypit is offline   Reply With Quote
Old 05-13-2005, 11:23 PM   #17
70c10
67-72 Addict!
70c10's Avatar
Brandon- Thanks man, that's the one. Ron did an excellent write up on this.
Jim
Old 05-14-2005, 09:34 AM   #18
GMC69mnypit
!Women...!!!!
Yeah, I agree. Excellent write up, and I like the look of the behind the bezel install the best.
I've been gathering parts for my try at this. The 3 3/8" gages are getting hard to find, I don't like the "phantom" series personally, so I'm going with procomp because I want them all to match.
If you're having trouble finding 3 3/8" and want to go with the procomp series, I know Advance Auto parts still can get them. I just ordered a fuel gage, autometer #5514. Oil psi was p/n 5507, water temp was #5505 (if I remember correctly from Ron's writeup). Their web site shows the last two as 3 3/4", but I think that must be a typo.
I ordered online http://www.partsamerica.com/ProductL...artnumber=5514
