C10 Club Tennessee
Just cut my springs and I'm not feeling confident about it!
Hey guys,
I asked this a while back and finally decided to get a blade to my skil saw today. These are the factory springs that I sold with my yellow 69. Th PO said I could have them. I can't be sure that the ones on my truck now have been tampered with. Well, I cut one coil off from the bottom (the fat end) and it just didn't seem like that much. I thought maybe some guys here had some measurements on a 2 inch drop spring I could compare to. That is the drop I'm after, because I have drop spindles also. Thanks, Bryan
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
Geoff
I don't know how low you want to go but from my experience once you go over 2 or 2 1/4 coils the ride gets pretty bad. With 15x8 245/60/15 with the above mentioned coils cut my front bumper on my 68' was between 6-7in off the ground.
Sometimes you don't notice much and then you take another coil and your like holey crap what did I do. Good luck
68 SWB, 5/7 drop 406sbc. HR cam & dart iron eagles Th350 w/3000 stall H4 headlights and LED taillights |
67-72 parts collector,…
![]() Join Date: Nov 2002
I've found that 1/2 coil= 1 inch drop. You should be around a 2 inch drop. If you cut more,... just remember that the spring will be loose in the spring pocket with the front wheels off the ground. (example: jack under frame, not the a-arm,... and front wheels off the ground) This isn't a problem,... you just need to make sure the spring "seats" in the spring pocket when you lower the front back to the ground. I've cut 1 1/2 coils with no problem. Had them on a daily driver I use to have. This was way back,... before dropped spindles were available.
C10 Club Tennessee
It just seemed like the the bottom coil was pretty close to the second to the bottom coil. Which is now the bottom coil. It just didn't seem like it would be that much of a drop.
thanks lolife Bryan
You are looking at 2 1/2- 3 " of drop,with 1 ring off the bottom......my longhorn has run that way for 10-12 yrs, with no issues
http://community.webshots.com/user/hotrodhorn |
#6 | |
Señor Member
Quote "Sometimes you don't notice much and then you take another coil and your like holey crap what did I do."
![]() ![]() ![]() Sorry But that is friggin funny!
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
#8 | |
![]() Join Date: Nov 2003
Coil springs are cheap, keep cutting
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#10 | |
Señor Member
#11 | |
#12 | |
'72 Chevrolet C10- Deluxe/5.7/Short Fleetside '02 Chevrolet Tahoe- LT/5.3/4x4 '13 Ford F150- XLT/5.0/SuperCrew/4X4 '14 Subaru Impreza- Limited/2.0/Sedan/AWD |
#13 | |
Happy to be here
![]() Join Date: Mar 2000
#14 |
C10 Club Tennessee
Okay Guys,
I'll leave it alone and install them with the drop spindles and see what I got. I guess like N2Trux said I'll drive it before I get mad about having to pull it back out.
#15 |
i you cut 1 coil off front, how much do you cut off back coils to level the truck out?and do you need to get different shocks with that much drop?
#16 |
You can't cut the rear coils. The way the spring is designed is like a pig tail, it spirals in at both ends. You will have to buy drop coils or bag it. Yellow69 here is a picture of my sons truck 2 1/2 drop spindles with stock springs with 1 coil cut out and 6 inch drop coils and 2 inch blocks in the back.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA Last edited by 72BLAZERDUDE; 05-23-2005 at 10:35 AM. |
#17 | |
FWIW.... they all rode like crap.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-23-2005 at 04:19 PM. |
#18 |
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
#19 |
Well I'll admit it's not something I would do but he did things differently. I also must admit that although his trucks rode slightly on the rough side, he never had any issues w/the rear springs.
The tops were still bolted in place just like the factory & the bottoms were tacked to the trailing arms. One of his trucks was hit broadside hard enough to rip the bed loose from the frame but both springs were still in place. I liked his 3rd attempt the best as it offered more support. Years later, he did a 65 & went w/dropped a-arms when I suggested spindles. It was one of those dropped a-arms that hung on a city manhole cover & totaled his truck. Mine was just as low & still drives around years later thanks to dropped spindles & mildly cut coils. At least on the 65, he stepped up & got dropped rear coils & we made some blocks for about 6" of drop.
