Old 05-07-2005, 07:04 PM   #1
72Bob
72Bob's Avatar
1970 396 Question
I just got a 1970 Big Block 3/4 ton truck, What I have read, it should be a 402, but the glove blox says 396 option code L47.
Is the 396 correct?, or should it be a 402? and what is the HP ratting?
Since the body is rusty, we thinking about putting it in a 68 Camaro body.
1971 GMC Sierra 3/4 Ton 4x4
1972 Chevrolet SWB 4x4
RIP LeRoy
72Bob is offline   Reply With Quote
Old 05-07-2005, 07:18 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
In the trucks, GM made things real confusing.
The engine ios a 402.
The option is for a 396.
The fender badge says 400.
The 396 and 402 are closer related than the other big blocks, the 402 is nothing more than a 30 over 396. There's many storys as to why, and they range from fire/flood damaged blocks to improperly bored blocks that ended up getting rebored, and inner office politics...just to name a few. Personally, i buy into the politics one.... GM couldn't have a small block being bigger than a big block, and in 70, the 400 small block was born. So they gave the 396 a quick shave and a hair cut and were pleased. However, in the high perfomance circles, the 396 had quite a following, and becouse of this, there were many 402 engines badged as 396 in the cars.
Confusing huh?
Old 05-07-2005, 07:32 PM   #3
72Bob
72Bob's Avatar
Great info.
I will check the bore when the motor is pulled.
Thanks, 72BOB
RIP LeRoy
