Old 05-07-2005, 10:49 PM   #1
ABHaulR
ABHaulR's Avatar
rear end ??
I have heard i think on this site that you can use the carrier from a 14ff in our HO72. if that is so what all is needed to do the change? if that the truth then i can buy a locker and gears for a 14ff and install it in my HO72. i can get a set of 4:56 for my rear end but i cant get a locker for it. any info would be great. i would like to keep the rear end in my truck since ive got the 3 link built and installed. thanks for the imput.
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 05-08-2005, 03:20 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
How many bolts hold the carrier to the ring gear on a 14 bolt? The eaton uses 12. Are you contemplating a 14b detroit in the eaton? if so you'd keep the eaton carrier and put the 14b detroit in it. The detroits for the eaton and 14 b are drop in style the carrier is the same between the open and detroit equipped trucks. Adam(1969 GMC) is assemblying parts to do this(14b detroit into eaton carrier w/ 14b axles) now.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-08-2005, 12:17 PM   #3
ABHaulR
ABHaulR's Avatar
can you use a 14ff carrier in our eaton rear ends? im just looking for a way to lock the eaton so i dont have to remount all my rear bars and shocks and so on.
Dwayne
Old 05-09-2005, 07:18 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I believe a 14 b has 14 bolts on the carrier/ring gear, the eaton only has 12, I don't think they'll line up.
