Old 05-07-2005, 11:25 PM   #1
ryanroo
ryanroo's Avatar
Hei ????
I installed my hei today and its running better than ever, but i was wondering what size inline fuse i should be running from the fuse panel to the dizzy cap
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-08-2005, 12:01 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
25 amp should be fine. Go too small and you'll get a high end miss fire. In all reality, you could go with a 30 or bigger (do they even make them bigger in normal fuses?) if it shorts to ground, it'll blow what ever you put in there regardless of the amp rating.
Old 05-09-2005, 12:59 AM   #3
ryanroo
ryanroo's Avatar
Thanks Andy
another question, when i unhooked the balast resistor, there was a green wire that ran from it to the elec. choke on my edelbrock 1406. what should i connect this wire too. it was hooked to the same terminal that the yellow wire that runs to the starter was hooked to.
Ryan
72 K20 12v build
Old 05-09-2005, 10:28 PM   #4
Longhorn Man
Just run a wire inside to a switched power point on the fuse box. ACC or IGN would work.
