Old 05-08-2005, 06:48 AM   #1
70GMCer
70GMCer's Avatar
Van Column ?
Well, I was starting to go thru my 78 Chevy van tilt column yesterday, to clean it up and ready for install, and found a problem. The turn signal switch is broke where you screw in the turn signal arm. My question is, does anyone know if the 68 thru 72 tilt column repo signal switch work on this.
I've found 78-81 switches OEM, but the prices are a little high. They look the same as our truck ones and could save some money using those......
steve
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-08-2005, 08:05 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
check the connector for similarity. I have one of each in my garage, I will have to check later today
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 05-08-2005, 08:12 AM   #3
70GMCer
70GMCer's Avatar
Pretty sure the connector is differant. Been looking at pictures of the 68-72 tilt switches, they look identical. I've also emailed GMC Pauls about this. Hope they are the same.......
1997 GMC Sierra Ext
1965 Mustang
Old 05-08-2005, 10:10 AM   #4
dmec
dmec's Avatar
you dont need to replace the whole switch, just the turn signal cam. the truck shop in orange, ca has them for $6. part #67-06703. phone 1-800-243-8947
dmec is offline   Reply With Quote
Old 05-08-2005, 10:14 AM   #5
70GMCer
70GMCer's Avatar
I'll check them out.......thanks......would still like to know though, if the the early switches would fit this column.....
1997 GMC Sierra Ext
1965 Mustang
Old 05-08-2005, 10:23 AM   #6
70GMCer
70GMCer's Avatar
dmec....do you have their site address?
1997 GMC Sierra Ext
1965 Mustang
Old 05-08-2005, 10:40 AM   #7
dmec
dmec's Avatar
the truck and van column parts will interchange.
www.truckandcarshop.com
Old 05-08-2005, 11:38 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the only differance that you may have is in the plug, which you can get an adapter if that becomes an issue.
Old 05-08-2005, 11:52 AM   #9
72MARIO
72MARIO's Avatar
New Flash
The wires on the van and truck tilt and straight coloums are the same you just need to pop them out and use the truck plastic plug.
The vans use a flat plug and the truck use a 1/2 Moon. Also the turn signal switches are interchangeable between straight and tilt truck and van. The only diffirence is the tilt have a light bulb for the gear indicator. You can remove the bulb socket and put it on your straight coloum switch. If you buy a Tilt switch they hit you up for a few more bucks for the light bulb socket.
Just a bit of info I discovered when rebuilding my van tilt.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 05-08-2005, 12:17 PM   #10
Longhorn Man
the early van tilts had the horse shoe connector.
Old 05-08-2005, 12:51 PM   #11
71swb4x4
71swb4x4's Avatar
When I replaced my switch I found that the terminals inside the plug were not the same, so I couldn't pop them out of the flat plug and put them in the horseshoe. Maybe there are different suppliers out there.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-08-2005, 03:19 PM   #12
70GMCer
70GMCer's Avatar
good advice and info.............thanks........
1997 GMC Sierra Ext
1965 Mustang
