Old 05-08-2005, 09:08 AM   #1
b454rat
Best steering column for a 62
I don't think the search thing likes me, I tried to search and kept coming up with nothing. I read in here somewhere about what steering colunm to use in 60-66 trucks, be darned if I can find it. I'm looking for the least amount of fab work to put a column in my 62. I have access to just about any type make and model of car and truck and van. I have the kit for the power steering box already, so I think I just havta shorten the shaft. Anybody?
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 05-08-2005, 12:10 PM   #2
carryallnut
steering
You are correct. If you have access to anything you want then all you have to do is shorten the shaft. Or you can take the entire shaft out of something newer and put it inside your column. It sounds like you will be converting to later model PS, so you might not have to cut anything. Try a column from a 67-72 truck, that should be very close. If you're lucky you will find a tilt column to boot.
carryallnut is offline   Reply With Quote
Old 05-09-2005, 03:45 PM   #3
b454rat
Ithink a friend of mine has some already pulled, I'll give it a try.
Old 05-18-2005, 04:04 PM   #4
gn4u2c
gn4u2c's Avatar
put a 75 el camino tilt in a 64 with a body lift . biggest pain is just wiring it up.
gn4u2c is offline   Reply With Quote
