FUEL CELL GURU
Blazer gearbox...
Is a 4WD power steering gear box useable on a 2WD if you change the steering arm?? Just wondering because I am gatering parts for the 4WD to 2WD conversion. Thanks, FuelCellGuy
No. Two wheel drive secures with a nut, 4x4 with a pinch bolt. If you are near Austin, I'll be happy to trade a 2x4 box for your 4x4. Two wheel drive boxes are used on 4x4 to do a crossover steering setup.
FUEL CELL GURU
Do you have a good 2WD box that doesn't leak and is tight??
