Old 05-08-2005, 06:25 PM   #1
lpaine
lpaine's Avatar
torque specs for eaton 10 bolt
I just swapped out the gears on the truck-went from a 4.57 to a 4.10 and have the carrier bolted back in-that is one heavy unit!- these old 10 bolts are pretty skookum, anyway I need to know how many ft. lbs. to torque the bolts to, I have lost that section in my old dog-eared-in-pieces chilton manual, dang-it time to buy another one I guess. Thanks in advance, Lew
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 05-08-2005, 09:25 PM   #2
Rod
ring gear torque is 110 ft lbs.
differential bearing caps are 100 ft lbs
carrier cover is 18 ft lbs
all these spec for the 5200-7200 eaton
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
