05-09-2005, 01:31 PM | #1 |
#16876
Darn, I cant get rid of that gassy smell!
My truck still has the gas tank in the cab. My truck is stock, so relocation is no option. Has anyone had a mild lingering gas smell? (not of the human nature). My tank does not leak. I have a new filler neck gasket and cap. Could it be the old hoses are emitting the odor? The smell is slight, but wont go away. Ayone with ideas?
05-09-2005, 01:54 PM | #2 |
67-72 Addict!
Check the O ring around the sender on top of the tank.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-09-2005, 03:04 PM | #3 |
Does it smell more when you fill it up, or all the time?
If its when you fill up you might want to swap out the filler hose.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
05-09-2005, 03:39 PM | #4 |
it's a good idea to replace ALL the original pieces of rubber hoses even the one under the cab going to the frame rail . and as mentioned the O'ring gasket for the sending unit also while changing that is a good time to clean/replace the sock strainer in the tank
05-09-2005, 03:57 PM | #5 |
gas smells good though... (mine usually does, a little more than usual at fill ups)
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
05-09-2005, 06:28 PM | #6 |
I would check what everyone else has suggested so far first. I had the same problem after checking everything the smell was still there, I bought a vented gas cap to fix it but it did not.
Some one posted pictures on how to cut the spring in the vented gas cap so it would vent better I did it and it worked great no more gas smell.
1998 Pontiac Grad Prix GTP 1969 C10 396 TH400 3.08 posi |
05-09-2005, 10:19 PM | #7 |
blood type; Retumbo
does it have the EEC feature where there is a hose coming from near the filler then goes up inside "B" pillar & back down. maybe this is venting.
just an idea.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
05-09-2005, 11:48 PM | #8 |
Check the rubber fuel lines attaching to the sending unit in the cab. If they are original I bet they are cracked. Had this happen in two trucks, lines look ok untill you take a real good look.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
05-10-2005, 12:09 AM | #9 |
its all about the +6 inches
if all this fails to net you a fuel less cab, look on the bottom of the filler neck where it joins the tank. (no hoses on these rigs) They often crack right there. Easy to solde.
One day this summer, you should probably gut the int of the truck, pull the cab, and scrub everything real good. There is probably small amounts of fuel that has soaked into the carpet and into the sheet metal/rust. |
05-11-2005, 02:45 AM | #10 |
#16876
I'll start checking hoses cracks ect. How does the sending unit come out? I don't see any screws. No carpet to hold the smell. Cab was just painted. No vent in pillar either.
05-11-2005, 10:43 AM | #11 |
I take it people are not allowed to smoke in your truck?? hee hee....
72 GMC Camper Special 2500. currently has 350/350/14 bolt. 383 and 400 tranny is in the works. |
05-11-2005, 11:23 AM | #12 |
Lovin' Life in Miss.!
Sending unit has a lock collar. There are tangs on it. Use a screwdriver and hammer to lightly tap counter clockwise.
The truck... you hear that? No really, you did hear that?!!! |
05-11-2005, 12:04 PM | #13 | |
#16876
Thanks Chicken wing. I suppose I had better get a new gasket before I take it apart.. Last edited by Sillyoldman; 05-11-2005 at 12:07 PM. |
05-13-2005, 03:01 AM | #14 |
I had the same problem, it was the hoses, I took the seat out to get a good look. That was the only way I could really get a good look at them. Once I replaced them the smell was gone.
