Old 05-09-2005, 08:47 PM   #1
Tanis
good idea or bad idea??
I would like to put disk brakes all the way around front and back. I would also like to change out the old 65 gmc rearend for something what i can put disk on. Also if anyone has a list of what is all needed for the front transfer from drum to disk would be great as well. "Could not find old post" Also would like to swap the 305 V6 for a 400 and swap the 4 speed with an auto do i need to change the driveshaft as well? Or would it be just as good to find an old junk GMC/Chevy and just start ripping it apart for the parts i want to use and if so what year/make/model would work. Everyones opinion is helpfull
Tanis is offline   Reply With Quote
Old 05-09-2005, 10:38 PM   #2
DM310
for the front just find a 73+ parts truck and buy the complete front suspension, not only would you get 5 lug disk you will have the better/cheaper ball joints. I paid $300 for a complete front suspension
66 C10 (under construction)
1.5" crossmember drop
2" Z'ed frame
8" rear notch
Watts-link
Bagged
DJM 3" spindles
DM310 is offline   Reply With Quote
Old 05-10-2005, 12:47 AM   #3
jchav62
1962 C-10
jchav62's Avatar
You will need to shorten or find a different driveshaft as the slip yoak and length would be different. As for the rearend, you should probably look for a later model one and find a disc brake conversion kit for it. I believe GMC's have a leaf spring rear suspension, I ain't sure. I know on coil spring Chevy's a rearend from a '72 would work with some minor fabrication. That is what my 62 has. Good luck.....
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-10-2005, 08:22 PM   #4
Tanis
OK sweet thanks guys
