Old 05-09-2005, 10:19 PM   #1
matthufham
new trans; driveshaft issue
i have a th400 i want to replace my 350 with, but i'll need a different, shorter driveshaft. how much do they cost because this is a swap i would really like to make. it's a longbed with a split driveshaft now.
matthufham is offline   Reply With Quote
Old 05-09-2005, 10:30 PM   #2
69 longhorn
the 2 pcs shaft in your 77 should have a slipyolk in the middle, just after the carrier bearing. I would swap the trans yolk & set it up......if you have 3/4" minimum in the center for "slipslide" , with the wheels on the ground, you should be ok. Just keep in mind that you need tween 3/4-1" on the slip yolk before it bottoms. if you need , you can cut & balance a shaft fairly cheap ($75-125 in my area).....the 400 t is worth the extra hassles, it one d@mn good trans. best of luck, L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 05-10-2005, 04:20 PM   #3
matthufham
i forgot to say i want to take the th400 from my 77 longbed and put it into my 72 longbed. both have 350ci engines and my 72 has the th350 right now. i was wondering about a driveshaft though because i don't think the 77's would fit the 72.
Old 05-10-2005, 08:36 PM   #4
69 longhorn
Is the 72 a 1/2, or 3/4 ton?
Old 05-10-2005, 06:17 PM   #5
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Fort Worth Gear and Axle.
I love those guys. They built me a sweet 1 piece drive shaft with a new yoke and u-joints for my 72 lwb.
Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
