Old 05-09-2005, 10:39 PM   #1
bozracer
wnc tvman
bozracer's Avatar
Replacing Door glass/Vent window
Any tricks to changing door glass and vent window assy?
Oz WNC
67 Short Fleet 350 4speed
70 Short Fleet 327 4speed
bozracer is offline   Reply With Quote
Old 05-10-2005, 01:01 AM   #2
4tiresngas
An American Soldier
4tiresngas's Avatar
Bozracer, I'm certainly no expert, but I have done it a time or two. I would say everything hinges on the vent assembly. With the window lowered, remove the 3 outside screw on the vent and the 2 screws on the lower vent support arm. Then pull the top of the vent towrds the rear of the door. Once it moves towards the rear, just angle it towards the inside of the door and pull it all the way out. You will have to twist it. You can now move all the other parts around freely...window, regulator. Slide the window forward to remove it from the regulator...there are notched openings in the regulator track.
The installation is the reverse. Get the window in and get the regulator arms in the window glass track. If you do remove your regulator for any reason, be sure to put it back before putting the window glass back in.
After the window is in place. Install the vent window reverse ogf how you took it out. Get the 3 outside screws in first by just nudging the vent window around til you get the screws started. You can use a screw driver in one of the vent support arm screw holes to maneuver the arm and get the first screw started. Put those 2 screws in and you are pretty much done.
I just did this a week ago...guess I should have taken pics...sorry
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 05-10-2005, 05:44 AM   #3
This may help. You can normally find alot in the FAQ section
http://67-72chevytrucks.com/vboard/s...d.php3?t=83475
http://67-72chevytrucks.com/vboard/s....php3?t=153937
Old 05-10-2005, 04:21 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-10-2005, 04:41 PM   #5
krue
Designated A-hole!
krue's Avatar
That's right!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 05-10-2005, 06:33 PM   #6
bozracer
wnc tvman
bozracer's Avatar
Better believe it. Thanks,Guys
Oz WNC
