Old 05-10-2005, 09:24 AM   #1
Big Blue
Big Blue's Avatar
Inner firewall insulation
Didn't know where to place this question, so if its in the wrong place please move.
I'm looking for or some other way to replace the insulation that was on the inner firewall under the dash.. I'm gutting out the cab for painting and want to replce this.
What other means have some of you have done?
Thanks John
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
Old 05-10-2005, 10:42 AM   #2
truckinbean
I got one from chevy duty http://www.chevyduty.com/frame-store.html for about $100. Do a search for 42-041, that's the part number for 73-79s, even though it says 73-87. Mine actually came from here though http://www.quietride.com/. The fit and finish was pretty good, but not perfect, and you have to punch out holes for the a/c and the throttle cable and such.
If I was going to do it over, I think I would go for some dynamat, because I think it would be easier and would do a better job of getting rid of noise. Some of the dynamat has a heat reflecting layer too.
Ben
'77 Blazer 2wd lowered 5/6
Goodwrench 350/700r4/3.73
Performer intake
Performer 1400 carb
Sanderson Headers/Dual 2 1/2" Flowmasters
truckinbean is offline   Reply With Quote
Old 05-10-2005, 12:08 PM   #3
Big Blue
Big Blue's Avatar
Thanks truckinbean,
Yea, I seen that in the chevy duty cat. $100.00, thought their might be a better but cheaper way. I plan on putting the other stuff on he floor to cut down on noise and heat.
Still looking for other suggestions.....
john
Big Blue ( John )
Old 05-10-2005, 12:15 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Brown Bread...
http://www.73-87.com/7387garage/inte..._deadening.htm
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-10-2005, 09:00 PM   #5
Big Blue
Big Blue's Avatar
Thanks Captkaos, I bookmarked that link for later. I was wondering about the factory type of insulation. Guess something is better then nuffin..Thanks
John
Big Blue ( John )
