Post Whore
![]() Join Date: Feb 2000
Unplanned maiden voyage
Took half of yesterday off and got my front shock towers installed and the front shocks installed. Then I proceeded to finish my home built power brake bleeder and bled the brakes. What a simple, cheap tool, and it worked awesome! Flushed all of the old fluid out and it is definitely a one person job using the power bleeder!
Got a little brake fluid on a rim so I figured it would be easiest to fire the truck up and get out of the barn to wash the rim off. I don't have a steering column installed but was able to get out of the barn easy enough. After I got the rim washed off I just had to try to go for a drive. I got the old column and connected it to the steering box loosely and threw on a spare steering wheel and fired the truck up. I had to drive holding the column up but I was able to drive to the end of the drive and back, probably 1/4 of a mile. I was all smiles. Found a small leak in the high pressure line going from the steering box to the hydroboost so I got it pulled last night and it is having a new hose installed today. My oldest daughter asked this morning when I was going to be able to take them to school in the truck - maybe if things go well I can before school is over this year. A bit more to do but I'm getting so close!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
lookin good Mark, can't wait to see her finished!
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Where's my beer?
I like that 4x4, also, ,that's a damn nice shop you've got there.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
i'm interested in the "home made" power bleeder!
Got pic's?
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 05-10-2005 at 12:14 PM. |
#5 | |
71 K20 350/350/205, dealer air, 4" lift, Flowtech,Edel 1406 on 2101, procomp HEI,4.10's, 33x12.50x16.5 BFG MT's on slots. 4 wheel disc brakes. My lame K20 page My lame Eaton disc brake page ![]() |
one set closer
Got pic's ![]() ![]() ![]() |
hydroboost
Nice progress, looking good!!
Question for you though...what setup do you have for your hydroboost and how do you like it? Could you post or email me some pics? I've been thinking about this type of setup, but don't know anyone that has used them. Thanks,
'72 C10 lwb 454/TH400 |
when did you paint it??
I love the color... was thinking the same for mine...
72 GMC Camper Special 2500. currently has 350/350/14 bolt. 383 and 400 tranny is in the works. |
Post Whore
Beefcake - It went to the body shop during February of 2004 to be back in 1 month . . . didn't get it back until October of 2004.
As for the power bleeder I found a couple websites that talked about making your own and since I do most of my truck stuff alone I had to make one. You take a garden type sprayer and cut the wand off of it, leaving the hose. I added a pressure gauge as you don't want more than 20 lbs of pressure. Then I got a small flat piece of metal a little larger than the brake booster lid and drilled and tapped it for a fitting that I could attach the sprayer hose to. Then I use two c-clamps to secure the flat piece of metal to the brake booster. The fitting is positioned so I can just turn the flat piece of metal 180 degrees so I can do the back brakes then the front brakes. I will get some pics of it tonight. Here are the links I used to make my setup - it is well worth the few bucks it takes to make one. http://www.arkansaspontiacs.org/tech...er%20story.htm http://www.bmw-m.net/TechProc/bleeder.htm
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 05-10-2005 at 02:01 PM. |
Post Whore
ac102nv - the big block and the hydroboost system came from a 1989 1 ton Chevy. I am also using the hydraulic clutch setup. So far it looks like it will be nice but I am not roadworthy yet so will have to wait for a final decision. I made a reinforcement for the firewall as the hydroboost is pretty heavy and a couple people mentioned reinforcement would be wise. I will dig up some old post links showing this setup.
Here is an old post http://207.44.196.117/vboard/showthread.php3?t=86446 but unfortunately my website is down right now so the pics aren't all showing up. PM me your e-mail address and I will send you some of the pics.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 05-10-2005 at 02:08 PM. |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Broke
Did you get on it a little and turn those big meats over?
72CheyenneSuper1ton4x4BigBlock Last edited by Bram; 05-10-2005 at 05:31 PM. |
#13 |
Post Whore
Unfortunately I didn't have time to take everything off the bed so I couldn't jump on the gas - I would have been picking up stuff for hours
#14 |
Broke
LOL I hear you. I bet your foot is still itchin?
72CheyenneSuper1ton4x4BigBlock |
#15 |
Post Whore
Big time!!
#16 |
![]() ![]() Join Date: Jul 2002
Thanks for the bleeder links Yukon. Glad it is coming together. Before you know it, you'll be needing new tires
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 05-10-2005 at 06:21 PM. |
#17 |
Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Looking Great Yukon...Keep the Progress Pics a Comin'
Brian Smith ![]() 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
#18 |
It's Done When It Runs!!
Trucks looking good. Good thing you didn't get on it, It would have been a shame to spill that COLD BEER.
#19 |
Got Light Emitting Diode?
next project, build a brake bleeder
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
#20 |
Sure looks alot different from three years ago, sweet!!
#21 |
Its Magically Delicious
yukon .. thats what i call a work bench ..... glad to hear the news
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
#22 |
Post Whore
That unfortunately was not a cold beer from that day of wrenching, but the remains from a few days ago.
It really is a handy workbench and like a workbench it is very messy! Thanks for all the compliments and it has come along way in the last 3 years - further than I would have ever guessed I would have it. After all it is just my work truck for around the house . . .
#23 | |
#24 |
Just like to part out trucks!!
Looking good Mark, your doing a great job!!!!!!!!
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
#25 |
Still drivin' a Rat Rod
Gotta love it when a plan comes together.Truck looks great,bet you have some new inspiration now
![]() I like the 4x4 work step beside the tire,I use one of those also ![]()
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
