Old 05-10-2005, 03:11 PM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
Got my front shocks mounted
I got my front extended shock mounts installed yesterday along with my Rancho RS9000X's installed. Will have to wait to the rear shocks until I can drive to a friend to have him weld them on.
Also got my brakes bleed yesterday and took my first test drive Still away to go before road ready, but I'm getting there.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-10-2005, 04:28 PM   #2
GMC71k20
are those shock towers from a ford? how much bigger of a shock can you run with it?
GMC71k20 is offline   Reply With Quote
Old 05-10-2005, 04:41 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Yes, those are the Ford shock towers. The length of shock will depend on if you have a body lift and if you use your inner fenderwell or cut the inner fenderwell. I went with a little longer shock so if I go with more lift later the shocks will still be useable. These shocks are 36" fully extended and like 21" fully collapsed for about 14" of travel. As mounted the front shocks could compress about 6" which is definitely more than my springs will allow. Got tons more droop than I will ever use also.
Old 05-11-2005, 08:22 AM   #4
72longbed
72longbed's Avatar
Question
Yukon,
what brand shocks are they? I just bought a set From Tuff Country and they mounted in the opposite way. Are you sure the cylinder mounts at the top?
72longbed
72longbed is offline   Reply With Quote
Old 05-11-2005, 11:41 AM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
These are Rancho RS9000X's. Their tech department verfied this shock can be ran in either position but it would be better to have them with the cylinder down. I want them in this position as it places the adjustor where it is protected and easier to get to.
Old 05-11-2005, 01:23 PM   #6
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Looking good. What all else do you need to get done to get it up and driving?
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-11-2005, 01:30 PM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
I still need to mount the oil cooler, install the grill + side markers, install the door guts and weather stripping, adjust the passenger door as it is rubbing a little, get the steering column back from the painter, get it mounted and modified due to the body lift and then she should pretty much be ready to go. A trip to get exhaust done is also in order once it is roadworthy.
