Attaching A-Arms
Anyone ever have trouble putting 73-87 bottom A-Arms on a 70 crossmember...getting the pins to line up properly???...that and the same year U-bolts being a little large. I see that the 70's Ubolts are a size smaller....I put the Ubolts in the vise and gently squeezed...took care of that problem....still the alignment pins.
I'd greatly appreciate anyone's feedback in this issue. Thanks... Billy G
My FAMOUS LAST WORDS...."Ima Gonna!!" - 1970 GMC 1500 swb/step 250 I-6 3 spd - "The GEM" - 1976 Chev Scotsdale swb/step 350/350 - "The JEWEL" - 1982 Chev C-10 swb/step 250 I-6 3 spd - - 2001 Chev Silverado LT - |
ttt
blood type; Retumbo
I have never done this. but why would you use the later arms with the sloppy rubber bushings? 73-87 ball joints will fit the 70 arms & then you will have more accurate & ridgid suspension.
what I have heard of is using the "saddles" with the larger pins & u-bolts from later. just cut the rivets off & install them on your 70 with some leaf spring center bolts.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Weekend Warrior
I had a little bit of an issue when doing it - but i used the '69's u-bolts. the pins lined up but it took a bit of cussing and getting pissed.
keep trying man they should go in
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
Got em in...just took the right words....lol....and attitude. Put little floor jack under the arm....lifted the arm into place by hand...then supported. Worked like a champ on the 2nd side.
Thanks for the comments... Billy G
#6 | |
Weekend Warrior
See...sometimes you just gotta get mad at it and cuss a little...they eventually cooperate and if not you can always break out the "BFH" (Big F***** Hammer) or the "Firewrench" as i like to call it (oxy/fuel) ![]()
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 05-11-2005 at 11:05 PM. |
