05-11-2005, 11:44 AM | #1 |
Brakes problem on '67 C10
I had a brake job done about 15k miles ago. They have worked well until several months ago. With increasing frequency, the brake pedal goes to the floorboard with no resistance, and I have to pump the pedal to stop. I am not experiencing any brake fluid loss at all. Any tips on where to start troubleshooting will be appreciated.
------------------------------------- Tim '67 C/10, '04 Tahoe ------------------------------------- Last edited by briarpatch; 05-11-2005 at 03:59 PM. |
05-11-2005, 12:42 PM | #2 |
67-72 Addict!
Have you pulled the wheels to verify the wheel cylinders are not wet?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-11-2005, 02:45 PM | #3 |
Master cyl. by-passing? That's where I'd look first.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
05-11-2005, 04:17 PM | #4 | |
Resident Curmudgeon
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
05-11-2005, 05:00 PM | #5 |
Thanks for the responses. I'll have a look at the wheel cylinders, but it looks like the consensus is to replace master cylinder...
------------------------------------- Tim '67 C/10, '04 Tahoe ------------------------------------- |
05-11-2005, 08:11 PM | #6 |
member #16
Don't forget to check the adj. the self adjusters have been known to malfunction. This will also cause you to pump them up. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
05-11-2005, 09:21 PM | #7 | |
05-11-2005, 10:34 PM | #8 |
Yup, it sounds like you have a bad master cyl.... L
http://community.webshots.com/user/hotrodhorn |
