Old 05-11-2005, 07:02 PM   #1
Deuce
Deuce's Avatar
Question ATTN TPI Guys!!!!
What did you do for a throttle cable?? My 67 had a rod from the carb to the gas pedal rod. The TPI set-up I have has the throttle cable?? Do I need a different gas pedal assembly??
Thanks.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 05-11-2005, 10:08 PM   #2
neonlarry
neonlarry's Avatar
You can modify a 71-72 cable setup to work.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
