Old 05-11-2005, 07:39 PM   #1
aztxk5
This really is the fix!
Guys,
I have always had weak brakes on my blazer. Well I read about swapping in a 3/4 ton brake booster and was sceptical but it is the fix! I can lock em down now it feels much safer than before. I kept the original M/C and just changed the booster. Easy, easy, $99.00 at the local parts store.
Al
aztxk5 is offline   Reply With Quote
Old 05-11-2005, 07:43 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I've heard about others doing that too. Good to know! Is your truck lifted? Are you still running 1/2 gear?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-11-2005, 07:52 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-11-2005, 08:48 PM   #4
Scrubby
Check out GMTrucks.org
I did the same and the difference was night and day. I went the junk yard route, but for $99, I should have probably got new. Same deal though, before my brakes were really weak and I kept trying to adjust the rears to get it to stop better. I put in the 3/4 ton booster, and bam, I could lock up the tires. I highly recommend it also.
My blazer is lifted 4 inches and is running the 1/2 ton gear still.
Scrubby is offline   Reply With Quote
Old 05-11-2005, 09:45 PM   #5
71jimmy
71jimmy's Avatar
Cool, I read about that on the "other" blazer board. (can I say that?) Sounded like an excellent idea. Going to try it myself. What type/year booster did you get?
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 05-11-2005, 10:29 PM   #6
Medicanman71
Medicanman71's Avatar
are you talking about blazers w/ out discs in the front? My blazer (With brand spankin new breaks and master cyl.) stop about 1000X better then a 2001 Durango SXT 4x4 i drive sometimes. I hate that abs junk it has too. I dont know about "locking up" the tires !?!? My rears did that just fine before i fixed them, heh heh.
Medicanman71 is offline   Reply With Quote
Old 05-11-2005, 11:08 PM   #7
aztxk5
My Blazer is a 71 with disc brakes lifted 2" with all stock running gear. I couldn't believe the difference.
A couple of things, get a new vacuum hose about 4" longer because the booster is deeper and the bracket from the firewall to M/C will no longer fit. But I have a fix for that and as soon as I get ir done I will post a pic.
There are a lot of so called fix's posted on these boards but again, this one works!
Al
Old 05-12-2005, 12:12 AM   #8
skid
I agree with all the above posters. I put a 3/4 ton booster and a C3 Corvette M/C (for future rear disk brakes) and it has excellent feel and incredible stopping power. I made a new plunger rod as well for the M/C so the brake pedal barely moves (less than 1/2") before I get the solid feel of the brakes. They feel better than any new truck, no mushiness at all.
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 05-12-2005, 06:40 AM   #9
vtblazer
vtblazer's Avatar
Could you use the 3/4 ton master?
Would it change anything if you did?
I guess not having to disconnect brake lines would be a plus.
vtblazer is offline   Reply With Quote
Old 05-12-2005, 08:57 AM   #10
aztxk5
You can use the 3/4 ton M/C, but it plumbs the opposite of the 1/2 ton. Also I don't think there is an advantage, I believe the rod dia. is the same.
Al
Old 05-12-2005, 12:20 PM   #11
71jimmy
71jimmy's Avatar
Al
YUP, what he said!
