Old 05-11-2005, 08:22 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
Engine backfiring
I just put the engine in my 71 anf it back fires once it is warmed up...any ideas???
1971ChevyTruck is offline   Reply With Quote
Old 05-11-2005, 09:07 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
timing
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 05-12-2005, 12:18 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Sounds to me like the carb idle is too lean if it runs ok while the choke is on and then it backfires when it's warmed up. try turning the idle screws out one turn each. The best way is to set them with a vacuum gage.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-12-2005, 10:54 AM   #4
67chevemall
67chevemall's Avatar
Where do you guys hook your vacuum gauges up to????
I would go with the mixture screws aswell. 1 turn
67chevemall is offline   Reply With Quote
Old 05-12-2005, 04:23 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
vacuum gage
http://www.classictruckshop.com/club...ts/vac/uum.htm You will need to have full manifold vacuum, so connect the gage where it reads manifold vacuum below the carb. Use this link for info.
VetteVet
Old 05-13-2005, 02:36 AM   #6
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
some more details will help.
is it backfiring all the time?
just when you step on the pedal?
'70 chevy lwb w/'67 hood.
357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada.....
'82 honda v45 sabre"the black"
CHEVIBUBBA is offline   Reply With Quote
