Old 05-11-2005, 10:53 PM   #1
ozzyracing
How to lower with rear leafs
What is the best way to lower my truck in the rear with a leaf spring suspension setup? I am looking at 4 inches in the rear of 65 GMC swb fleetside. Also, any photos of such?
65 SWB 454 350T
ozzyracing is offline   Reply With Quote
Old 05-12-2005, 03:01 AM   #2
kamikazegmc
Registered Smarta$$
kamikazegmc's Avatar
a flip kit will give you 5" or shakles and hangers for 4" or some drop leafs 4"-5" it all depeneds on how you want to do it.
63 GMC custom
going to be slammed
kamikazegmc is offline   Reply With Quote
Old 05-14-2005, 12:20 AM   #3
cheyenne10
cheyenne10's Avatar
flip kit
I am considering flip kit but do not have the answer yet how this affects my load capacity and ride.
Bob
cheyenne10 is offline   Reply With Quote
Old 05-15-2005, 01:11 AM   #4
NO LONGER DISTURBED KONCEPTZ
NO LONGER DISTURBED KONCEPTZ's Avatar
It shouldnt have much affect on the load capacity. You are just putting the rear end on top of the leaf instead of under it. The leafs capacity remains the same. You will have to have some type of notch in the frame to keep some clearance though. Also you need to run a lowered shock. Shackles and hanger are a good way to go and if you get a set of drop leafs that are at least a 3 leaf pack then you will be good with those. If you want to haul anything.
NO LONGER DISTURBED KONCEPTZ is offline   Reply With Quote
Old 05-17-2005, 03:08 PM   #5
ozzyracing
is it fairly simple to do with shackles? Also, I have 15x10's with 295 50 15's, will it accept much of a drop on my 65 without changing my new tires and the wheels?
65 SWB 454 350T
