Old 05-12-2005, 12:37 PM   #1
phanatic32212
It's Done When It Runs!!
phanatic32212's Avatar
Red face Need Voltmeter Advice
I just got a new Autometer voltmeter 8-18 volts. When I turn the ignition it reads 12V like it's supposed to, but when rev the engine it jumps up to 18V even with the headlights on. I know that it is supposed to go up under load, but that high? Also, will this do any damage to gauge, being pegged out for a decebt period of time?
TIA
phanatic
Or Give Me DEATH
phanatic32212 is offline   Reply With Quote
Old 05-12-2005, 12:47 PM   #2
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
If I were you I would take a Digital Multimeter and check the voltage at the battery when it's running. It sounds like your regulator isn't regulating, since the new voltmeter reads 18V. Good way to fry some things quickly. Voltage should not go above 14.8V if it's working correctly.
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt."
Ben Franklin
1970 Chevy shortbed
2002 Harley Custom Chopper (Long sucker)
1998 K2500 5.7L 5-speed Longbed
1st two are My son's toys...they just live in my garage!
1997 GMC K1500 Suburban
1993 S-10 Blazer 4D (youngest son's daily driver)
2000 Dodge Ram 4WD Ext. Cab (5.9L)
Wife is a late year 1951
Old Dave is offline   Reply With Quote
Old 05-12-2005, 12:50 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
I'd check with a regular volt-ohm-meter. Your voltage reading should be 14.3 to 14.8. 18 volts will boil you battery to a premature, explosive death.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-12-2005, 12:55 PM   #4
jhow66
jhow66's Avatar
I'd say your gauge is off(like my autogauge from autometer). If it was putting out that much you would see a big rise in headlight brightness.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-12-2005, 01:19 PM   #5
phanatic32212
O.k. I checked the battery off:12.2V idle:14.4V then watch meter as i rev the engine and it goes up to about 15.5. the guage is right on at OFF, at idle the guage says a little more than 15V and under load the guage pegs out at past 18V. Should I call JEGS and get a new guage or is it something else. I thought Autometer's guages were calibrated and good to go out of the box.
Or Give Me DEATH
Old 05-12-2005, 02:29 PM   #6
Putter
More Cowbell....
Putter's Avatar
Just out of curiosity...where did you make the connection for the volt gauge? To an ignition wire under the dash, under the hood, etc...????
You might want to take the alternator to the local parts house and have it tested....it's free to do...that way you will be 100% sure that is not the issue before you give Jeg's an ear-full.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 05-12-2005, 02:29 PM   #7
Ackattack
Ackattack's Avatar
I think the gage is fine.
I think your alternator is probably putting out 18V or more. Taking a reading across the battery is not a correct indicator (internal resistance) Measure the output of the alternator and compare to the gage.
Ackattack is offline   Reply With Quote
Old 05-12-2005, 04:16 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Have you been having problems with your vehicle. Why don't you test another vehicle with your voltmeter and see if it does the same thing or if it reads ok. If it reads ok on another vehicle then your regulator is bad as the others have said. Do you have an internal or external regulator?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-13-2005, 02:00 PM   #9
phanatic32212
I want to thank all of you guys for keeping me from looking like a jackass. I was going to call JEGS and raise hell about this meter. Instead, I went to PepBoys and bought a voltage regulator for less than $30 and sure enough, 14.4V. You guys are geniuses!!! Thanks a bunch. I'll be back and hopefully I can give some info next time.
Or Give Me DEATH
