05-12-2005, 03:26 PM | #1 |
Its a Truck Thing......
Suburban/Blazer tank filler options
If any is in a jam for an option to get a filler neck hooked up for the burb/blazer tank, heres what I did.
Got the filler neck from cool caps, cant remember the number but I heard you can get the same one from a marine parts place, picked up 4ft of 1 1/2 duraflex fuel hose (over kill on the length) 3 couplers and 1 ft of duraflex 1 1/4 hose. Ive tried every store and no one carries 1 1/4 fuel hose, (thanks alot for the odd size to the manufacturers of the blazer/burb remanufactured tank), anyway the duraflex hose can be bent anyway you want and it will not collapse (has steel core lines in it), this stuff is the same type of hose on gas pump lines. Probably will last forever. Besides the filler neck everything cost about $50. If anyone is in a bind I will get this stuff for you and ship it out. I put the neck in my wheel well. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
05-12-2005, 03:42 PM | #2 |
More Cowbell....
I am using the same brand of fuel hose on mine. But...mine is 1-3/8" hose for my 1-3/8" filler neck on my reproduction tank.
I ran it to the side marker filler location. Where did you get those clamps? Those look pretty sturdy.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 05-12-2005 at 03:49 PM. |
05-12-2005, 07:45 PM | #3 |
I got them from Hampton Rubber, If you need some let me know I'll pick you up some. There about 3.50 each...
Smitty
05-13-2005, 05:38 PM | #4 |
Great post! Thanks!
Alex 1971 Lil' Red 350 SBC 700R4 |
05-13-2005, 06:05 PM | #5 |
Got Light Emitting Diode?
i got some tough hose clamps from napa
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
05-13-2005, 07:13 PM | #6 |
Hope it helps, Also test fitted the tank and figured out I have to c notch a cross sill, oh well, couldnt go in perfect.
Smitty
