Old 05-12-2005, 08:57 PM   #1
laplander
Question How to do you tell a van tilt from a truck tilt?
I'm getting ready to start looking for a tilt for my 72, but am not sure how to tell the difference between a van or a truck column. I'd rather not pay a premium price and then find out I bought a more plentiful van model. Any help would be appreciated.
Nik
laplander is offline   Reply With Quote
Old 05-12-2005, 09:59 PM   #2
tnblazerk5
User #12137
tnblazerk5's Avatar
on a van tilt the steering shaft sticks out farther than a true truck tilt theres like 2and 1/2 inch differance in them the van being the longer one
tnblazerk5 is offline   Reply With Quote
Old 05-12-2005, 10:01 PM   #3
laplander
Is there a tell tale sign to look for if you don't have a stock one to look at? I've seen a couple on ebay but am hesitant to go for it without knowing for sure.
Thanks,
Nik
Old 05-12-2005, 10:08 PM   #4
dmec
dmec's Avatar
i have van tilts that have been converted to truck specs and if i didnt tell you, you wouldnt know the difference. and they are cheaper than buying an original and rebuilding it. have them for column or floor shift.
dmec is offline   Reply With Quote
Old 05-12-2005, 10:21 PM   #5
Rod
van column on left...note the higher neutral safety switch location and the longer lenght of the shaft out the bottom.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-13-2005, 01:19 AM   #6
ROBBY WHITE
ZOIE AND ZACK
ROBBY WHITE's Avatar
Dmec How Much Are Your Tilts Column Shift?
AMERICAN BULLDOGS AND CHEVY TRUCKS
71 1/2 SUBURBAN 402BB IN PROGRESS
90 1/2 TON SILVERADO
02 1/2 SUBURBAN
67 GMC 1/2 TON LONGBED
05 AVALANCHE
ROBBY WHITE is offline   Reply With Quote
Old 05-13-2005, 03:08 AM   #7
dmec
dmec's Avatar
all prices to your door
painted semi flat black $295
powder coated semi flat black $320
powder coated chrome/clear $370
Old 05-14-2005, 01:26 AM   #8
toddsdaler
nik,,, a few easy ways are to look at the length of the shaft sticking out past the tail baring (the van is longer then the truck) and the neutral safety switch on post 74 columns is high on the column and the truck is low...also i think before 74 the van column had the horse shoe plug like the truck turn signal harnes plug...after that it was a flat in-line plug also a dead give away that it is a van column... also if the column if fresh out of a van it will have a big rubber weather boot at the base of the column... van column are the same thing with a few very easy modifications... i have 6 van columns that i will be shaking down and putting on ebay... i only payed $20.00 to $40.00 and they are seriously/realistly worth about $125.00 top dollar for a premo... but i see guys get $175.00 to $250.00 for a van column... whatever...but thats the price that true truck columns start there price at...
toddsdaler is offline   Reply With Quote
Old 05-15-2005, 07:28 PM   #9
Rod
Look at how there advertised on ebay and such..the van tilts are for the street rodder crowd also....so its not always a truck bidder your up against.
