Old 05-12-2005, 10:20 PM   #1
CoryM
oil pressure guage readings in psi?
Anyone ever figure out what psi the factory guages read?
e.g. 15psi @ 1/4 sweep, 30psi @1/2 sweep
Just would like to have a rough idea and asking here is easier than hooking up a gauge .
Cheers.
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada
http://www.geocities.com/chevroletc1070
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
Old 05-12-2005, 10:25 PM   #2
lamar
lamar's Avatar
Most of the oil pressure gauges are 60lbs gauges. Some are 80lbs but came in mostly larger trucks. If you take the oil pressure gauge out of the cluster it should say on the face which it is.
72 C-10
lamar is offline   Reply With Quote
Old 05-12-2005, 10:32 PM   #3
CoryM
Thanks man. Didnt remember seeing it written on the face but I have a spare gauge around here somewhere from the same year/model truck so I will peek at that.
Thanks again.
