Old 05-12-2005, 10:29 PM   #1
Labdad
Labdad's Avatar
Angry Motor Problems
Just had motor rebuilt, now the oil level on the dip stick is high, and the oil smells like gas. Fuel pump is new. Bad? Any other ideas?? First day back from off frame restoration, now this.
31 Ford
57 Chevy BelAir
63 Nova SS Convertible
67 Chevy Stepside
78 International Scout (will sell)
91 Chevy Blazer
96 Chevy Blazer
97 GMC Jimmy
02 Silverado EXT
Labdad is offline   Reply With Quote
Old 05-12-2005, 10:31 PM   #2
Johns70
Johns70's Avatar
sounds like a bad fuel pump maybe a couple of cylinders not firing.
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 05-12-2005, 10:33 PM   #3
1STtimePRo'71
1STtimePRo'71's Avatar
I agree on the cylinders. Good Luck
-Cory
1967 2 Wheel Chevy
1STtimePRo'71 is offline   Reply With Quote
Old 05-13-2005, 04:04 AM   #4
4x4Poet
A small hole in the fuel pump's diaphragm can allow a portion of the fuel pumped thru to leak down into the block opening behind the pump where the pump's eccentric lever sticks thru. If so, the gas flows into the pan from there. Pull the pump and check if the diaphram holds vacuum.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
